We've got several single bin augers that don't have any sort of baffle in them and have very very rarely had any problem with them. The piece of tubing on the anchor bearing that slides inside the flighting acts as a restrictor to limit the amount of feed the auger takes. As long as you never cut that piece of tubing shorter you should be fine unless your motor is undersized. When you go to a tandem bin setup the second bin doesn't have an anchor and if you don't have a way to restrict the flow of feed into the flighting I'll promise you it will plug and it doesn't matter how big your motor is it isn't going to turn it. I've got one plugged right now and I'm hoping it warms up soon because it is a real PITA to unplug a flex auger. Pretty much involves pulling the flighting out to empty it out and then reinstall it, never fun but even less fun when its sub-zero. I'm pretty sure my plugged up auger had to do with all of the snow that I got in the bins about 6 or so weeks ago (whenever that blizzard was), haven't needed that feed line since then but I will need it soon. |
