Search Forums | Classifieds (95) | Skins | Language
12V air compressor
notillgleaner
Posted 1/5/2011 13:59 (#1528481)
Subject: 12V air compressor
Central Kansas
Want a decent size electric air compressor to use for transfering fuel and the ocasional flat tire.  I know I've seen them mentioned here before, but can't find it in the search.  What brand or size is worth the money?
Edited by notillgleaner 1/5/2011 14:31
FFJR
Posted 1/5/2011 14:22 (#1528514 - in reply to #1528481)
Subject: RE: 12V air compressor
nc IA
try searching for precision planting air compressor or service truck air compressor?
Jon Hagen
Posted 1/5/2011 14:31 (#1528536 - in reply to #1528514)
Subject: Re: 12V air compressor
Hagen Brothers farms,Goodrich ND
The little "cigarette lighter" type 12V pumps are pretty limited, as I believe the lighter socket can only supply 15-20 amps. Only good to pump up a low car / pickup tire.
The "truck" type 12v compressors that clip right to the battery are supprisingly fast pumpers when filling tires. Still under $100.
scott nelsen
Posted 1/5/2011 15:22 (#1528606 - in reply to #1528481)
Leeds, North Dakota
I can look tonight, don't know what it cost, about 1 1/2 foot long about 1ft high, 200 psi 12 volt to battery, Scott.
moonshine
Posted 1/5/2011 15:57 (#1528650 - in reply to #1528481)
Idaho
http://buzzardgulch.com/CatalogV2.htm
Applicator
Posted 1/5/2011 16:08 (#1528666 - in reply to #1528481)
This is the most powerful, most expensive 12 volt air compressor I have ever seen. http://12-voltair.com/
WTW
Posted 1/5/2011 16:13 (#1528672 - in reply to #1528666)
Winkler, Manitoba Canada
I think the specs on this one are similar, both cfm and dollars. http://www.aircompressorsdirect.com/Oasis-Manufacturing-XD4000-12-A...
pointrow
Posted 1/5/2011 16:43 (#1528712 - in reply to #1528666)
Central Il Morton
Applicator - 1/5/2011 15:08 This is the most powerful, most expensive 12 volt air compressor I have ever seen. http://12-voltair.com/
How much is it ?   Precision Planting's 12 volt compressor is $2400.
later
pointrow
Applicator
Posted 1/5/2011 18:53 (#1528905 - in reply to #1528712)
WOW! you got the most expensive part, I think Voltair is less than 1/2 that. I saw it at the Tulare Ag show last Feb.
pointrow
Posted 1/5/2011 20:20 (#1529172 - in reply to #1528905)
Central Il Morton
Applicator - 1/5/2011 17:53 WOW! you got the most expensive part, I think Voltair is less than 1/2 that. I saw it at the Tulare Ag show last Feb.
I wonder if the voltair would hold up to holding air pressure all day for a planter setup and the dust? May be a alterintive to PP"s air compressor.
later
pointrow
Posted 1/5/2011 19:16 (#1528980 - in reply to #1528481)
We have 2 of the Puma 12V compressors. They're well-built & good. Not like the little cigarette lighter plug-in jobs. I think it draws something like 20A (or more?) at full load, so it has substantial wiring & needs good hookup. It has a regulator of it's own. Motor is BIG!
http://compare.ebay.com/like/190484731988?var=lv&ltyp=AllFixedPriceItemTypes&var=sbar&rvr_id=194281839774&crlp=1_263602_309572&UA=WXI7&GUID=4807ea2c12d0a040b1501470fffcfe26&itemid=190484731988&ff4=263602_309572
99guy
Posted 1/5/2011 20:13 (#1529158 - in reply to #1528980)
North Central MO
I use one like Ron's (Puma) except I have one with twin tanks. Not sure of amp draw either but I will pop a 50 amp fuse once in a great while on heavy use or maybe when I did not leave the service truck running to keep volts up. For limited use it's about the best I could find for the small amount of space I had available on this particular truck. If I really need do so something that's not just an emergency type deal the gas driven compressor gets loaded in the back.
You might change an implement tire with an impact but you will have to wait for it to pump up more than once due to the small storage capacity.
scott nelsen
Posted 1/6/2011 11:04 (#1530446 - in reply to #1528481)
Leeds, North Dakota
http://viaircorp.com/OffRoad/20008.html Scott.
