| In your place last spring, bought an 8230 with an IVT tranny. Put 500 hrs on it this year, in heavy tillage (30' FC, 6 bottom plow, subsoiler) the transmission pulled as good as a powershift. One thing I noticed is that when running tandem plowing with our 8300 powershift was that on the ends when you first started the tractor would slow down then build speed up to the set speed, this was more evident especially if it was a hard pull. On lighter loads there was a significant difference in fuel savings. Not so much on the heavy work. Pulling a Pickett Twinmaster bean combine it worked well there with not having to be constantly shifting between gears, alot smoother. Overall in my experiance it was a good tranny no problems, not sure if i prefer it over a powershift though. | |
