Search Forums | Classifieds (28) | Skins | Language
John Deere 9430 smoking bad? Any ideas
shank
Posted 11/8/2010 20:04 (#1427505)
Subject: John Deere 9430 smoking bad? Any ideas
I have a JohnDeere 9430 4 WD that has 400 hours and it started smoking bad all of a sudden and lost power.I think its loading up on fuel? Took it to dealer and it not throwing any codes.They been looking all day and cant figure it out.Any ideas?????Put new fuel and air filters in it too.
Joelt
Posted 11/8/2010 20:16 (#1427525 - in reply to #1427505)
Subject: Re: John Deere 9430 smoking bad? Any ideas
Top of Texas
My 9330 has had the same kind of problem. Deere blaming it on the EGR system, although they have yet to get the problem fixed despite several attempts. Mine ran poorly for several weeks before i started getting codes related to the EGR coming up.
road tech
Posted 11/8/2010 20:16 (#1427526 - in reply to #1427505)
MANITOBA
EGR VALVE OR SENSOR FOR EX TEMP
Chad H
Posted 11/8/2010 20:33 (#1427568 - in reply to #1427505)
Subject: RE: John Deere 9430 smoking bad? Any ideas
NE SD
9230 does the same thing only it throws a code. 1347.07
I think that is a FPRV code. Dealer claims they fixed it last winter but it still does it. Real handy when pulling something through a tough spot when it lets go.
jj4910
Posted 11/8/2010 20:37 (#1427583 - in reply to #1427505)
SE Wyoming
Anxious to see the responses. We've got one too. Just started using John Deere fuel protect. Dealer's first recommendation.
waites tractor
Posted 11/8/2010 20:45 (#1427609 - in reply to #1427583)
northern ny,
have you got water in fuel filter . what color smoke black, white. is it on start up under load .what rpm range or is all time . is a rocker arm out of adjustment in rack . orings bad on injectors just dumping fuel in cyl.
jdchipup
Posted 11/8/2010 21:25 (#1427725 - in reply to #1427609)
North Battleford Saskatchewan
what color ssmoke do I watch for black,blue surly not white
riceman4300
Posted 11/8/2010 21:35 (#1427752 - in reply to #1427505)
South Louisiana
I have a 9330 that smokes as well. I have had a couple of 9300s and 9320s and none of them would smoke unless you set them on fire. This tractor has smoked since day 1. There are a few others (9330s) that I know of that smoke like mine. I think JD has something amiss but they dont have an answer for this problem yet. I have never seen a new tractor smoke like this. There is no way this could pass an EPA emission test.
jj4910
Posted 11/8/2010 22:10 (#1427821 - in reply to #1427505)
SE Wyoming
Ours smokes black. It isn't a huge cloud, but is definitely more than the 9420's. It is accompanied by an exhaust flutter when the engine is warm. Smokes more on start up than the 20's too.
johnypop
Posted 11/8/2010 23:53 (#1428012 - in reply to #1427505)
ND
Have your dealer flush the fuel system, worth a try.
KelB
Posted 11/9/2010 02:31 (#1428088 - in reply to #1427505)
Subject: Could it be somthing simple like an aftercooler hose
Ayr Queensland Australia 4807
blown off or split load the engine and listen for a noise
mrplumberg
Posted 11/9/2010 07:07 (#1428166 - in reply to #1428088)
Subject: RE: Could it be somthing simple like an aftercooler hose
Nemaha County
Most of the time with an ECU 1347.07 code, the Suction Control Valve on the pump is sticking. Also you need to check your oil level, there was an update on engine oil dipstick length. You may be overfilling the engine oil.
Chad H
Posted 11/9/2010 08:56 (#1428363 - in reply to #1428166)
NE SD
Yes, our book says 8.4 gallons but 7.4 gallons is the correct amount.
bt1970
Posted 3/29/2012 20:02 (#2311990 - in reply to #1427505)
Eastern ND
The first person to put together an "off road kit", egr delete etc, for these tractors is going to make a killing.
TraxterMaster
Posted 9/30/2012 22:36 (#2616930 - in reply to #2311990)
Quebec, Canada
bt1970 - 3/29/2012 20:02
Its available now. With the new EPA standards "off road kit" also need an EGR. Lets call it Race Track or Testing kit hihihih. Contact me at [email protected]
