one shank subsoiler and drainage ball
deanw
Posted 6/18/2010 22:10 (#1242280)
Subject: one shank subsoiler and drainage ball
any one know who makes one of these and what the cost might be thanks dean
Dingaling
Posted 6/18/2010 22:27 (#1242313 - in reply to #1242280)
Subject: RE: one shank subsoiler and drainage ball
Owings, Maryland 38.6856 N 76.6752 W
Deere made a single shank subsoiler back in the day, you could weld a chain and ball on any of them I reckon, just as well to put a big enough tooth on it to achieve more fracturing/disturbance.
Several short lines probably off something but may not be worth the trouble, I think the Deere was numbered as a 12 but I am not sure. Do a search, Google is your friend............
NEILFarmer
Posted 6/18/2010 22:30 (#1242319 - in reply to #1242313)
Subject: Re: one shank subsoiler and drainage ball
Morris, IL
According to web site john deere builds them. Do they work?
jps51248
Posted 6/18/2010 22:33 (#1242333 - in reply to #1242319)
nw Iowa
I have a JD laying in the shed. Not sure if they work or not. Have never had to use it. It is for sale!! jps
deanw
Posted 6/18/2010 22:44 (#1242362 - in reply to #1242333)
does it have a ball to pull behind and what brand. how much thanks dean
jps51248
Posted 6/18/2010 23:13 (#1242423 - in reply to #1242362)
nw Iowa
Yes it has the ball, last time I looked. I think it is a JD. jps
t-boss
Posted 6/18/2010 22:41 (#1242355 - in reply to #1242280)
sc ia
My neighbor's got a home made one. He calls it a mole. I've borrowed it a couple times and I think it helps some.
play in the dirt
Posted 6/19/2010 11:16 (#1242876 - in reply to #1242355)
south central IOWA
If it helped, why do you still have wet spots and did we find any water coming out of the starting points? :-)
deeredriver
Posted 6/18/2010 22:42 (#1242359 - in reply to #1242280)
Alma NE
Back home they are called a mole plough maybe if you search that you might get some more info
Edited by deeredriver 6/18/2010 22:42
boog
Posted 6/18/2010 22:44 (#1242364 - in reply to #1242280)
I use to own a Blu-Jet 3 shank subsoiler. It would work a 200 hp tractor. Back in the '50s we pulled a single shank with a SM, with an M chained to the front for good measure.
Not sure if it here on NAT or where but someone recently posted a pic of a single shank 3pt unit that they were wondering about using to put in shallow tile with. Might try doing a "search."
KDD
Posted 6/18/2010 22:53 (#1242381 - in reply to #1242280)
Leesburg, Ohio
There was the occasional one tried around here several decades ago in the wet spots. You know what? Those spots are still wet unless they've been tiled out!
Maybe there is a soil type somewhere on this earth that it might work in for a week or two. But if the soil is wet enough to need it, it's probably not going to keep enough structure to let any water flow. I've never seen one work.
if you're going to the trouble to run a single shank ripper, why not pull some tile in?
Edited by KDD 6/18/2010 22:55
5288
Posted 6/18/2010 23:10 (#1242410 - in reply to #1242381)
S.E. South Dakota
A friend of my dads pulled a JD single shank with the ball and chain in his low spots.It was very dry that fall and gave his 4755 MFD all it wanted.It really helped is farm.No were to tile them too.
greenpower
Posted 6/18/2010 23:13 (#1242422 - in reply to #1242381)
N/E Iowa
i have an ole' one shank deere, with ball and chain. painted up and sitting in my "rock garden" The old guy that I rent ground from said It took 90 plus hp to pull it in black ground? He said he pulled it with a 4020, and would pull it 12 to 14 inches deep.
Edited by greenpower 6/18/2010 23:14
BSchroeder
Posted 6/19/2010 10:59 (#1242857 - in reply to #1242381)
Devils Lake, ND
Newly-drained muck ground subsides too much the first few years for tile. The grade changes.
KDD
Posted 6/19/2010 13:06 (#1242973 - in reply to #1242857)
Leesburg, Ohio
I guess no one told them in northern Ohio that muck ground can't be tiled...it's been working there for over a hundred years. Alot of the best ground up there was the old "Black Swamp" before it was drained with tile.
BSchroeder
Posted 6/19/2010 20:49 (#1243342 - in reply to #1242973)
Devils Lake, ND
The would let it subside a few years for it to settle and then install tile.
And the Black Swamp contains little, if any, muck. I'm from there.
Gifford
Posted 6/19/2010 05:18 (#1242639 - in reply to #1242280)
East Kansas, DeSoto
Back in the late 40's and 50's in my area used for the side hill seeps and in so called theory of the day help build sub soil moisture. Farmers were remembering the drought years of the area. In clay soil pulled so hard seldom used. Did not go over to well. Gifford
jrmac
Posted 6/19/2010 10:43 (#1242851 - in reply to #1242639)
NWMO
John Deere still sells them. Bought one last winter & used it this spring. They do make a diffrence. Under $1500 should get you a complete unit.
GoldenLeaf
Posted 6/19/2010 11:23 (#1242881 - in reply to #1242280)
Eastern NC
http://www.deere.com/servlet/ProdCatProduct?tM=FR&pNbr=0022BP
