Search Forums | Classifieds (7) | Skins | Language
8010 combines
GREEN FARMER
Posted 6/10/2010 19:38 (#1232061)
Subject: 8010 combines
central mn
Anyone run a 8010? If so, what do you all think of them? Look pretty simple to me.
spartan8283
Posted 6/10/2010 19:49 (#1232074 - in reply to #1232061)
Subject: Re: 8010 combines
Pierce County North Dakota
Buy a new one, the first ones out were full of bugs. The new ones seem ok. I speak from experience we had a new one in 2005 and another in 2006 and now run a 9870. We ran both (9870 and 8010) side by side in the same field and the case was always .3 to .5 mph faster (everything was even) The only reason we run a 9870 is Case IH (the company, not the dealer) Wouldn't fix minor/major issues. That being said I can't wait to switch back to red.
commissioner
Posted 6/10/2010 20:24 (#1232117 - in reply to #1232061)
southern Illinois
Neighbor had three, was always a red man but now runs green combines. That tells me something. He said for the two years he ran them a good day was when 2 were still cutting at the end of the day.
dko_scOH
Posted 6/10/2010 20:33 (#1232126 - in reply to #1232061)
Subject: RE: 8010 combines
39.48, -82.98
That's what we run. It's a solid machine -- but has all available updates. All brands have their quirks and all will eventually give trouble. Overall, the 8010 is a good machine. It has a lot of capacity and did a decent job of keeping the crop in the machine last fall, when everyone "here" was having so much trouble.
If I were buying today, I'd go with the 8120, though. All of the high-end combines are now jam-packed with sensors and miles of wiring. The day of keeping a combine ten years is about over, I think. If one sensor fails, there you sit. In contrast, our old 1680 is probably still purring away somewhere, with over 9000 hours on it.
CaseFarmer
Posted 6/10/2010 20:52 (#1232152 - in reply to #1232126)
Flora IL
Yeah but other companies do a better job with there electronics. It does sound like this xx20 series is much improved. Hope they keep building the 6088's for a long time :)
Luckyfarmer
Posted 6/10/2010 22:03 (#1232272 - in reply to #1232152)
Central South Dakota
We had a neighbor try em, swiched back to green in less than a year. Tells me what I need to know.
WTW
Posted 6/10/2010 22:25 (#1232331 - in reply to #1232272)
Winkler, Manitoba Canada
What does your neighbour switching combines tell you? One of my neighbours switched from green to red some years ago and is still running an 8010. Seems to be happy with it and or the dealer. Never noticed that the machine is down a lot. Covers a lot of acres in a timely fashion with one machine. Another neighbour who runs a 9770 Deere is probably equally happy with his choice of machine and dealer. Not sure if either of them changing brands would signify anything very significant.
Edited by WTW 6/10/2010 22:26
jasonl
Posted 6/10/2010 22:37 (#1232365 - in reply to #1232272)
midwest
All that tells me is, what does your neighbor know!
(9120 4.jpg)
(Fall_harvest_2009.jpg)
Attachments 9120 4.jpg (51KB - 820 downloads)
Attachments Fall_harvest_2009.jpg (97KB - 837 downloads)
flatlick farmer
Posted 6/10/2010 22:53 (#1232414 - in reply to #1232365)
West Kentucky
Compared an 8010 and a 9770 last year in wheat harvest. We were satisfied with both machines, especially once the wheat dried. When the wheat was 16-23% moisture, the 9770 could handle the heavy straw better. Other then that, they both did great.
Newguy
Posted 6/10/2010 22:52 (#1232410 - in reply to #1232152)
WC MN
Your 100% right......   Lexion came out with advanced electronics 5 years before the limited release of the 8010.  Our new 8010 (one of the last ones made) came before last harvest.    Sieve adjustment were a mess, think its fixed now.  Thought after many different yeild monitors throughout the last 15 years I though FINNALLY a monitor that is easy and actually works!!!!!!!!    Then it went kapputt.
Dealer came through, crop came out, stuff got fixed, but my opinion of engineering on the red beast is sub par.     For the guy who said something about not owning a combine for more than ten years because of electronics (i think thats what was said?)   Lexion has had it fugured out....I'd even say they are bullet proof (aside from fire)...
 Last year was a bad year to judge a combine, wet wet wet, hoping to keep an open mind throughout this season......   For the guy who said his neighbor traded to green and thats all he needed to know,  I got a neighbor that bought two new 9770's, one ran flawless, the other had 4 total days without either shutting down, or having the tech out.
Shoot, even lexions break down.
CaseFarmer
Posted 6/11/2010 07:23 (#1232741 - in reply to #1232410)
Flora IL
Thats a Lie!!!!!!!!!!!!!!!!!
ChrisTN
Posted 6/10/2010 23:19 (#1232477 - in reply to #1232061)
Ethridge, TN
8010/7010, not bad machines, BUT, would be a whole lot more reliable if they quite cutting corners on the materials they used to build them. Just way to light in the metal department for what they are supposed to be. To many wear parts built to thin to stand the wear the capacity is going to put on them. Early production models, definitely run in the other direction.
bnobles
Posted 6/11/2010 01:18 (#1232663 - in reply to #1232061)
Qulin, MO
Had an '04 8010. Everyone knows they had bugs. Case IH took care of us on that one for the 3 years we had it. Warrantied everything for all 3 years. We never had any major problems after that first year. They upgraded it to rice specs after the first year.
Got an '07 now. Bought it ready for rice. Only problems with it have been a sensor here and there. And when we ran a 3-point hitch sway block through it. That caused a bit of damage. Been very solid.
We have a 9120 with tracks coming in a month or two.
bnobles
Posted 6/11/2010 23:27 (#1233713 - in reply to #1232663)
Qulin, MO
Guess I get to take what I said about the 9120 back. Went by the dealership today and it had just been delivered. They were cleaning out a spot in the shop so that they could pull it in and put the tracks on it.
9700
Posted 6/11/2010 08:15 (#1232788 - in reply to #1232061)
That is a common observation of them, yes. Chain and belt drives were minimized on this machine compared to its twin (rotor) counterpart and first-born NH CR chassis. The reasons were two-fold. First, CIH marketing understood that incorporating more hydraulic drives would present the appearance of simplicity (not to mention allow them to carry over some of the design attributes of their CBX concept machine) and second, for engineering expediency. Remember, the NH CR was very close to release when the CNH merger happened, and the CR was on track to hit the market about a year earlier (2002), but CIH said no way, the 7010/8010 must be released at the same time as the NH (otherwise, it would make the red one look like a copy or a derivative of the NH, which of course we all know it is anyway). So the 7010/8010 project was really on the fast-track and hydraulic drives are much easier to package into as much of a common frame as possible. So that is the why.
The combine is still doing essentially the same number of functions that a yellow, silver, green, etc. one is doing. If you don't like lots of belts, you'll like the 8010. If you don't like lots of hydraulics, you probably won't. It isn't so much that the machine is so greatly simplified in overall function than anything else, but it has taken the use of hydraulics/hydro-mechanical drive to a greater level. Overall, the machine has some real strengths and things to like. It also has some areas for improvement, same as any other machine.
magnum8930
Posted 6/11/2010 13:04 (#1233032 - in reply to #1232788)
RRV, MN
We run a 07 8010, really good machine, put the 08 style feeder chain tightener on it. Version 25 software made the pro 600 alot faster. Lots of capacity. We found with wheat it likes to be full, if you try to baby it we were starting to throw over. Keep em full they work really nice.
