Search Forums | Classifieds (146) | Skins | Language
Adjusting 4020 shift linkage
blakezr2
Posted 3/19/2010 23:43 (#1127506)
Subject: Adjusting 4020 shift linkage
WC Iowa
How do you set the linkage lengths for the shift lever on a '71 4020. On one we replaced the parts in the shift lever mechanism and now will pop out of the lower gears (3-5-7-8) and the other 4020 we bought is very hard to shift out of reverse.
Bubbaspb
Posted 3/20/2010 09:19 (#1127752 - in reply to #1127506)
Subject: RE: Adjusting 4020 shift linkage
Western WI
Disconnect the lever from the rod down by the battery box. Put the transmission in the gear you want and adjust so that the rod fits in the hole in that lever. If it continues to pop out out may be have to replace the spring behind the detent which is in the same area. Make sure the shift lever is tight to the transmission case so that the shift cam isnt sloppy. Clear as mud?
As far as the one shifting hard.....Is the clutch adjusted properly?
blakezr2
Posted 3/20/2010 10:00 (#1127796 - in reply to #1127752)
Subject: Re: Adjusting 4020 shift linkage
WC Iowa
The 4020 with the reverse problem.... The clutch is adjusted. It only shifts hard coming out of reverse, almost have to kick the lever to get it out. but it goes in fine except for sometimes it pops out of gear when i first put it in to reverse. It shifts just fine in and out of all other gears.
msb
Posted 3/20/2010 11:04 (#1127869 - in reply to #1127796)
Lapel, In
Pull the detent out and have a look at the detent plate and the detent. An old approach was to replace the detent with a ball and socket detent from a 2010 transmission.
Gerald J.
Posted 3/20/2010 12:25 (#1127974 - in reply to #1127752)
Subject: RE: And while the link is disconnected:
And while the link is disconnected look for wear of the end of the link and the hole it runs in. If that's elongated you will have trouble shoving it into gear and pulling it out because the throw is limited by the mechanism in the dash and the link wears on both ends.
Gerald J.
