Mid-Missouri | Hi. We have an 04 7810 with electric perkins. I do not like the engine. The auto glow plugs dont come on until about 20 degrees f. It starts very poorly, sometimes smokes, sometimes not. Does your starter spin the motor over very fast, ours is draggy weak and just had a new gear reduction starter put in that didn't last 10 starts and god draggy. Do you rely on the onboard codes (cycling key off-on two times). Ours show about every code possible, dumb thing. We bought it with 400 hours and it still is the same at 950. Thanks for the info. |
