Search Forums | Classifieds (141) | Skins | Language
Fiberglass hood repair?
Bob Cen MI
Posted 2/1/2007 16:53 (#97681)
Subject: Fiberglass hood repair?
What is involved in the repair of a truck hood with a couple cracks?
The hood is off Volvo semi and has cracks near each headlight. No pieces missing just cracks in the corners about 6 in long from hitting something. I know it is a process of an epoxy type material with two parts plus a mat of fiberglass to add strength. I was planning on grinding or filing at the joint to increase the thickness of the repair. Where can I find these types of material for this job?
Thanks Bob.
Ranger Ted
Posted 2/1/2007 16:56 (#97683 - in reply to #97681)
Subject: RE: Fiberglass hood repair?
Montpelier Indiana
NAPA or other car parts places.
Stanley
Posted 2/1/2007 17:00 (#97685 - in reply to #97681)
Cherokee Co., Iowa
My son ran our 140 JD lawnmower into a light pole and put a dent and cracks in the fiberglass hood probably 35 years ago. I don't remember what brand of patch we fixed it with but it is still holding. Think we got it from an auto supply store.
davpal
Posted 2/1/2007 17:18 (#97698 - in reply to #97685)
Mid Michigan
You can get some wonderful stuff now at wal mart. Bondo brand Fiberglass resin jelly. It is less than $10 dollars for a quart and they sell the fabric right next to it. It mixes just like very thin bondo and hardens very fast. In about 20 minutes in 70-80 degree weather it is done. Just cut a patch the size you need and use a flat plastic spreader and it will go on really nice and you will be done in a couple of minutes. Stuff is very strong and you don't have to wait 24 hrs for it to cure like the old stuff used to be.
dloc
Posted 2/1/2007 17:31 (#97707 - in reply to #97681)
Subject: Re: Fiberglass hood repair?
A couple of sources. West's site has the best educational materials and pioneered many of the fiberglass production approaches.
http://www.westsystem.com/
http://www.fiberglasssupply.com/
A reasonably quick read will let you make the basic choices like mat vs fabric; fast vs slow set resins; use of fillers; etc.
montfarm
Posted 2/1/2007 17:52 (#97722 - in reply to #97681)
Depends on how bad the damage is. I have repaired several hoods on trucks and to do it right you need to use BID fiberglass cloth and epoxy on both sides of the hood. Do as you suggest and grind out the cracks and fill with the cotton epoxy mixture. I drill several half inch holes thru the hood next to the damage to tie the two sides together and fill them with a mixture of epoxy and cotton fibers. Then apply the cloth when wet on one side and when cured apply the cloth to the other side. Use three layers on each side. When cured then sand and finish in a normal manner. Have used this on several grain trucks with damaged hoods some badly and none of them have failed. Get the supplies at Aircraft Spruce. Cloth works much better than mat. Learned from building airplanes.
Bob Cen MI
Posted 2/1/2007 22:06 (#97766 - in reply to #97681)
Thanks for all the replys. I have yet to buy the truck was just wondering what it would take.
Thanks Bob.
Bob Blue
Posted 2/1/2007 22:26 (#97788 - in reply to #97766)
Bob Take a trip up to Saginaw and visit The Gueguon Brothers that developed the WEST system.They will build you a beatuiful wooden boat for .5million. Been there , very interesting family. Bob
Bob Blue
Posted 2/1/2007 22:20 (#97777 - in reply to #97681)
Subject: RE: Parts store should have it all.
The West System is the best. I have used many gallons on wooden boats, farm equipment,, fiberglass fertlizer tanks, ect. Another idea, a hobby store that sells radio controlled airplanes. I got back into a hobby I left 50 years ago and have been using the 2 part airplane construction expoxy which comes in half pint jars. It is a low viscosity liquid that will saturate fiberglass which is need to strengthen fiberglass cloth. You might also look for fillers that a called chopped cotton fibers and microballons which when mixed with the resins, make a workable putty for a final finish for sand down. Grind out the v, drill as Rich said, make long thin strips of glass to lay in the v (or carbon fiber threads would be stronger) Construction sequence, , V, dust free, cover with resin(use small acid brush), lay in fiberglass strip covering each with resin when it is laid it and build up V . Let it cure and will have to use warm water to dissolve a wax substance the that comes to the top which is formed by the curing process. Then you could make an expoy filler with chopped cloth microballons for the final fill. Advantages, super stong, water and acid resistant and will not crack, It is harder to sand and you need warm temperatures to use it , 65 -75 degrees to maintain viscousity and good curing. If you use heat lamps and get it to hot, it will go into a thermal reaction, smoke and blister and end up with zero strength. If you are sensitive to certain chemicals, don't breath the fumes , wear rubber gloves ect. I have become very senstized to it after 30 years of using it and am very careful with it. Bob
