..considering it is one of the highest fuel inputs on a grain farm. A couple of things to consider... Any dryer having a cooling section, including towers and Delux, will have less ability to steep grain at full temp, and effeciency compromise. Tower dryer are not the answer in a continuous flow, dry-aeration set up, in my opinion ( have no hard numbers to bolster this). Majors gains can be made by going dry-aeration with heat recovery.
Dryers that can either mix grain (or invert the column) will be more efficient thatn those that cannot. Top dryer are efficient because of heat recovery from the steeping/cooling grain. If you can find a creative solution, such as proper heat recovery at the dryer, plus heat exchangers for the cooling bin, you will meet and likely exceed the efficiency of top-dryers. Some of the most efficient number i have seen posted, in terms of BTU per bushel-point, is from Shivver Manufacturing http://www.shivvers.com/ They have done reserach experimenting with new methods, including advanced heat exchange http://www.reeis.usda.gov/web/crisprojectpages/203116.html
Edited by badger@uw 12/24/2009 16:29
