Mid-Missouri | We have had this center pivot Hesston 1345? for about four or five years. It has one rubber and one metal roller. The adjustment bolts for the top roller have given fits this season, breaking off once or twice. The top roller bearings went out a year ago, and I replaced them. I think I reversed the top, rubber roller when the bearings went out, so it would wear on the other side a year a year ago. What is the proper way for adjusting the depth of engagement between the two rollers. I am guessing you allow the rollers to fully engage, then slide the bent gauge toward the metal arm, and then adjust the rollers a certain distance away from the bent gauge. How far should it be? Also, when idleing down with it running empty, the machine vibrates, I believe from improper roller adjustment.? I have not been happy with the conditioning this machine does, and I believe a simple rotary mower that doesn't windrow in most cases would dry down faster than this wider machine putting hay in windrows. We do like the windrows tight enough though that one pass with the v rake will flip all portions of the two windrows into one. Thanks. |
