Search Forums | Classifieds (61) | Skins | Language
Cat c18
mkkm
Posted 1/28/2025 00:42 (#11077146)
Subject: Cat c18
Gilead Indiana
I was reading articles on this engine being used in the challengers. I understand why Agco went away from them, but did cat quit making them also?  I read they didn't meet EPA regs and then I thought I seen that they did. Just kinda curious,
Roblyn
Posted 1/28/2025 00:56 (#11077150 - in reply to #11077146)
Subject: RE: Cat c18
Good day
A CAT C18 is fiscally the same size block as a C15.....C16...and can be .mixed and match into a C17
Probably the only downside to the 18 is that the liners are a little more prone to electrolysis
Good luck
RecreationalTillage
Posted 1/28/2025 00:56 (#11077151 - in reply to #11077146)
West Central MN
C18 is still in production and used in many new Cat machines, oil & gas applications, marine, and gensets.
Here's an example
https://www.cat.com/en_US/products/new/equipment/articulated-trucks/...
The "not meeting emissions" is an old wives tale that won't die.
Jon
Posted 1/28/2025 06:39 (#11077244 - in reply to #11077146)
Callao Missouri
A c18 on a barko tub grinder can make a 1500lb bale of hay go poof. I can watch that all day, very satisfying.
71307140
Posted 1/28/2025 06:46 (#11077256 - in reply to #11077146)
Central Illinois - west of Peoria
Just installed a new set in one of our tug boats for use on the Illinois river , we’ve got 14 running from 475 to 600 hp
Usually get around 30,000 hrs on them before we pull them out for rebuild . Only weak spot we’ve seen is the lower counterbore liner o rings eat into the block - have to go to the machine shop and get bored and sleeved in that area . Some minor issues with injector o rings leaking also . We also have several Cummins QSK 19-‘s and we have better luck with the Cat C-18’s …..
I’d think the C18 would be an awesome tractor engine ..
No emissions on marine engines till you get over 805hp ..
Edited by 71307140 1/28/2025 06:49
(IMG_4283 (full).jpeg)
(IMG_4284 (full).jpeg)
Attachments IMG_4283 (full).jpeg (170KB - 19 downloads)
Attachments IMG_4284 (full).jpeg (169KB - 19 downloads)
Kelly
Posted 1/28/2025 07:20 (#11077323 - in reply to #11077256)
NC KS
Very interesting! I wonder why marine gets exempted on emissions in the lower horsepower classes?
Not much on it for drives. Is that a dropbox on the back of engine?
1070
Posted 1/28/2025 08:29 (#11077458 - in reply to #11077323)
south west in
Would it be that a marine running at a steady speed would be cleaner? Just a guess.
JD 9660
Posted 1/28/2025 11:02 (#11077688 - in reply to #11077458)
Southern PA
1070 - 1/28/2025 08:29
Wouldn't they run at varying speeds depending on how much push/speed is needed for the job?
71307140
Posted 1/28/2025 11:13 (#11077705 - in reply to #11077688)
Yeah these are harbor tugs - constantly on and off the throttle
WestMIguy
Posted 1/28/2025 08:35 (#11077477 - in reply to #11077323)
Kelly - 1/28/2025 08:20
Not much on it for drives. Is that a dropbox on the back of engineo?
The maritime industry has a very strong lobbying force. Just look at the Jones Act. I am guessing that has something to do with it.
jeff gordon
Posted 1/28/2025 09:47 (#11077602 - in reply to #11077323)
Mather, Manitoba
over 700hp exempt????
RecreationalTillage
Posted 1/28/2025 10:04 (#11077625 - in reply to #11077602)
West Central MN
750 hp is the cut-off point for non-road emissions
farmwithjunkrrv
Posted 1/28/2025 07:22 (#11077326 - in reply to #11077256)
South west of Winnipeg MB
71307140 - 1/28/2025 06:46
Do they cool with river water?
71307140
Posted 1/28/2025 07:36 (#11077347 - in reply to #11077326)
We have copper grid coolers that are recessed in the hull of the boat for heat exchangers- closed system and use antifreeze.
Gearbox is a Twin Disc 5170 marine gear with 5.17:1 reduction.
Don’t have a clue on the emissions issue - like most railroad equipment we run 24-7 - doesn’t make sense why a combine or tractor that runs 2-300 hrs a year has all the emissions and we don’t …marine and railroad have a better lobbying group than AG ???
Edited by 71307140 1/28/2025 07:39
1972RedNeck
Posted 1/28/2025 09:15 (#11077549 - in reply to #11077256)
Townsend, Montana
Is that a JWAC on the left side?
Any chance you could get me a serial number prefix?
71307140
Posted 1/28/2025 09:20 (#11077557 - in reply to #11077549)
TNA prefix
Aftercooler circuit on LH side , JW circuit on RH side
Separate circuit aftercooled …. Takes 2 coolers per engine
RecreationalTillage
Posted 1/28/2025 07:13 (#11077311 - in reply to #11077146)
West Central MN
One can still purchase a C18 in a tractor
https://www.mobiletracksolutions.com/3630t
jd8850
Posted 1/28/2025 08:09 (#11077410 - in reply to #11077311)
Roseglen, North Dakota
If I remember correctly that is the engine that was supposed to be in the much ballyhooed new Big Bud.
Not sure if even one has been made yet.
Edited by jd8850 1/28/2025 09:25
JD 9660
Posted 1/28/2025 10:58 (#11077685 - in reply to #11077146)
Southern PA
mkkm - 1/28/2025 00:42
You can buy a new C15 for trucks again, my understanding anyway. A C15 can be built into a C16, C17, or C18.
Hard to beat those engines, IMO.
CND
Posted 1/28/2025 12:23 (#11077802 - in reply to #11077685)
Anamoose, ND
I was told the C18 was bullet proof but found out this year that is not completely true. They now have an updated piston to fix this issue. Overall it was a cheap engine to rebuild.
(IMG_9636 (full).jpeg)
(IMG_9634 (full).jpeg)
Attachments IMG_9636 (full).jpeg (139KB - 19 downloads)
Attachments IMG_9634 (full).jpeg (139KB - 17 downloads)
Tazzerblue
Posted 1/28/2025 18:57 (#11078399 - in reply to #11077802)
Subject: Was that factory tune or something else??^^^
SW MN
Do you have a photo of the new/old pistons S/S?
CND
Posted 1/28/2025 19:30 (#11078443 - in reply to #11078399)
Subject: RE: Was that factory tune or something else??^^^
Anamoose, ND
Stock 865c. Old design was a two peace piston. Updated design is a one piece piston. I have no pics of the new design because the Cat kit had the pistons already in the sleeve. A friend from church had this happen under warranty twice.
(IMG_9632 (full).jpeg)
Attachments IMG_9632 (full).jpeg (106KB - 19 downloads)
