Search Forums | Classifieds (9) | Skins | Language
GroPak A.I. From AgXplore
PA Farmer1960
Posted 1/2/2025 20:40 (#11038429)
Subject: GroPak A.I. From AgXplore
Does anyone use GroPakA.I. for seed treatment? Or other products from AgXplore?
hone570
Posted 1/2/2025 20:55 (#11038449 - in reply to #11038429)
Subject: RE: GroPak A.I. From AgXplore
EC WI
Long time agxplore user. Ran Gro Pak AI last year, Revline Hopper Throttle in '23. Gro Pak was cheaper. Have always found Agxplores price was better than many of the big companies and superior quality formulations. Do some homework on their website, lot of good information.
npschaps
Posted 1/3/2025 11:41 (#11039081 - in reply to #11038449)
NC IA
Definitely a reason that GroPak is cheaper… just look at the product label and you’ll know why. 10x the biology and 6x more chelated micros in the HopperThrottle/TuneUp+ pail. Enough chelated zinc in the pail to replace liquid edta through the planter, there is less than 1/4 oz of zinc in GroPak… always amazed how other farmer’s always buy cheap and then say “boy they’ve got great prices and value compared to others” and they have zero clue they are getting totally hosed because they don’t read products ingredients.
il weedman
Posted 1/3/2025 14:12 (#11039219 - in reply to #11039081)
St. Charles, MO & Piper City, IL
The issue is that Gropak shows ROI. Hopper Throttle never seems to overcome the costs.
Dougy
Posted 1/3/2025 14:25 (#11039236 - in reply to #11039219)
il weedman - 1/3/2025 11:12
bingo.........$4/ac if bought right for corn. Beans even less
kgbarnett22
Posted 1/3/2025 14:31 (#11039244 - in reply to #11039081)
NE Indiana
Im not real sure what you're looking at but that's not even close to true.
Gropak has 1/4 pound of sulfur Revline has none. Gropack has 1/4 lb manganese Revline has .052 lb. Gropak has 1/4 pound zinc Revline has just under 1/4 lb. I used gropak last year and will use it again. It's cheap enough to throw in and doesn't cause any issues. We try to plant early so that's why we use it. If we planted later, I wouldn't use anything.
https://agxplorecom.sharepoint.com/sites/AgXSalesTeam/Shared%20Docum...
https://meristemag.com/wp-content/uploads/2024/12/LBL_Meristem_Revli...
A pail of revline is 5.78 pounds
A pail of gropak is 12 pounds.
Both of them treat 1 box of corn. Gropak is half the price.
mafrif
Posted 1/3/2025 16:19 (#11039368 - in reply to #11039244)
NC Iowa
How is revline 4% zinc on 5.78 lbs, but claim it has over 1.25 lbs of ionlock zinc, is this some conversion that only they know about?
hone570
Posted 1/3/2025 16:58 (#11039405 - in reply to #11039368)
EC WI
I have people reading labels and exploring websites. Everyday this time of year have a research topic to cover on your operations inputs. Shop and compare everything, lot of smoke and mirrors still in the industry.
Dougy
Posted 1/2/2025 21:14 (#11038475 - in reply to #11038429)
did last year
will again this year
half rate, rec rate is too much thru talc applicator.
mjr05
Posted 1/3/2025 20:45 (#11039706 - in reply to #11038429)
I've used Gropak for 6-7 years and this past year switched to gropak ai. As someone else said, use way less than the labelled rate, as the seed won't carry the labelled rate and it will end up in the hopper or in the wind. It's cheap. I think I end up <$2/ac at the rate I use. And it's showed +roi on my farm over multiple years of testing. I use it on every acre of corn and soybeans. I tested a few competitor products in the past and stuck with Gropak. It's usually the only, or one of the only, agxplore products I use, so it's not like I'm a slappy.
Edited by mjr05 1/3/2025 20:46
PA Farmer1960
Posted 1/4/2025 12:02 (#11040523 - in reply to #11039706)
Did you do a yield check of it? What difference do see using it?
mjr05
Posted 1/4/2025 15:50 (#11040873 - in reply to #11040523)
You made me check back through my records.
I tested their original formulation on corn in '18, '19, and '21. It was better in 4/6 comparisons and averaged 3.5 bpa better.
Beans I tested the original formulation in '18 and '20. It was also better in 4/6 comparisons but only averaged 0.7 bpa better.
Not a game changer, but for how cheap it was, and the fact that a decent amount of the cost was offset by the cost of the talc being replaced, I went with it.
I switched to the new Gropak ai formulation in 24 but didn't put any tests out.
Edited by mjr05 1/4/2025 15:50
PA Farmer1960
Posted 1/5/2025 11:36 (#11042108 - in reply to #11040873)
Thank you for your info. We have used Seed Coat from Delta Ag. Never did yield checks, did do stand counts. We put it on half the planter, was not consistent.
