WC MN | School Of Hard Knock - 10/27/2024 14:53
Lift the bale as high as you can, drop it on its face to break the ice on the net wrap. We use pallet forks to feed, so we pick it up after dropping with the forks, take a box cutter and cut as low as possible and peal the net wrap up and around. Tie the loose net wrap to the pallet fork, drop the bale in the feeder with the fork and if you do it right you should have all, or just a little remaining on the bale in the feeder that you use the pallet fork to fish out.
Feed 3-400? bales of feed over the MN winter this way. |
