Wisconsin | I'm not in southern IL so take it for what it's worth. If I could close up a building like that and run a smaller reasonably efficient AC, the cool air would stay near the floor, and the heat from the roof would stay near the roof. If you can keep the doors mostly closed, then the air won't change as fast as it would in the winter when the hot would run out the top and the cold would flow in at the floor. The top of the shed would already be hot so the density to drive the flow isn't as great.
That doesn't take into account if you're running forklifts inside, or you have east and west windows, or where the people are working inside, or any number of other factors. Here, A/C is nice for dropping the temp a few degrees, but lowering the humidity is the real life saver. | |
