Search Forums | Classifieds (85) | Skins | Language
Twisting off the 1000 pto shaft on 7120 CIH tractor.
CMCC
Posted 8/31/2024 11:24 (#10873547)
Subject: Twisting off the 1000 pto shaft on 7120 CIH tractor.
West Central Indiana
I have a 7120 with 8000 hours. It's been our 15' bush hog tractor since my dad bought it used in 1998 with about 2200 hours on it. It has done other things on the farm since then...but I'd bet most the hours are on the mower.
Two years ago a young guy was mowing for me and brought the tractor in with the 1000 shaft sheared off clean at the back of the tractor. It was leaking a little oil out around the seal. I had the dealer come out and install a new shaft and rebuild the pto clutch. I didn't think much about the twisted shaft...just figured it had fatigued from all the years of mowing. Yesterday a different guy (long time employee) that works for me said he engaged the pto lever and the shaft snapped off clean on the back of the tractor just like 2 years ago.
My question is do I need to sit them both down and go over how or how not to engage the pto? Is there a hydraulic setting to adjust how hard the pto comes on? Are these tractors prone to this issue? I bought a different mower 3 years ago. Could it be something with the mower causing the issue?
I got along great with this tractor/mower combo for so long. Seems odd to have 2 shafts broke within 2 years.
Thanks.
JAnderson
Posted 8/31/2024 11:32 (#10873555 - in reply to #10873547)
Subject: RE: Twisting off the 1000 pto shaft on 7120 CIH tractor.
McCanna, ND
Twisted/locked up pto shaft sheared the big 1 3/4” 1000 off our 4wd. I was slightly impressed a hollow tube could exert that much force without bending itself.
blowsand
Posted 8/31/2024 11:51 (#10873570 - in reply to #10873547)
mercer county, il
Does it have a cv joint on the front? Is said cv joint tight?
CV joints are a lot of weight hanging on there, and if they get a little bit of wear, that’s a lot of weight that’s trying to pull that pto off axis. If the shaft was actually twisted, I’d look at the operator as well as the metallurgy of the shaft. If it’s a clean granular looking break, I’d be looking at the cv shaft. That much weight at speed can quickly take a hard steel (brittle) beyond the kind of repetitive flexing it can handle.
tj_farms
Posted 8/31/2024 12:01 (#10873584 - in reply to #10873547)
Ohio
I broke my 8920 PTO just like yours. It ruined the seals, bearings and cast housing too. He'd to but a rebuilt PTO from France, only one available. $16,000 later, I'm afraid to use the PTO now
Jon
Posted 8/31/2024 17:10 (#10873867 - in reply to #10873584)
Callao Missouri
tj_farms - 8/31/2024 11:01
You've got to be kidding right?
The Pretender
Posted 8/31/2024 12:36 (#10873617 - in reply to #10873547)
The Internet
A place I worked once had a John Deere 3040 that snapped the PTO internally. There must have been a flaw in it, because it didn't have the grunt to snap a carrot in two.
mmaddox
Posted 8/31/2024 13:15 (#10873653 - in reply to #10873617)
Check the fill rate on the clutch pac.
dub
Posted 8/31/2024 18:56 (#10873929 - in reply to #10873653)
Clarksville, IL
tore out 8930 one up oh man been 15 years now if not 20, had to go to dealer to get split ruined stuff inside, guy came out said cv joint was gone on chopper, was only 2 years old, first one lasted 10 years, was told every 3 years replace no questions
Allen
tommyw-5088
Posted 8/31/2024 13:16 (#10873654 - in reply to #10873617)
Texas
I’d look at what it’s hooked to , we only ever broke one 540 on the 886 . Shaft broke and flopped around .
Those 71xx series are set darn hot , our 7140 sure is .
If they are kicking it in with a lot of engine speed , that could might cause it too ?
ccjersey
Posted 8/31/2024 13:24 (#10873665 - in reply to #10873617)
Faunsdale, AL
4320 here…….drawbar broke, pto shaft pulled out, flailed around and locked against 3 point arms….. Hollow shaft inside snapped. Never seen a JD stub shaft snap off……..yet……..
Edited by ccjersey 8/31/2024 13:26
School Of Hard Knock
Posted 8/31/2024 15:35 (#10873797 - in reply to #10873665)
just a tish NE of central ND
ccjersey - 8/31/2024 12:24
I could have shown you a bent one. Same deal. Lost a pull type combine on a 4320 and the pto separated and the stub shaft got bent out of round.
blowsand
Posted 8/31/2024 15:38 (#10873799 - in reply to #10873665)
mercer county, il
I think I’ve got 3 small 1000 stub shafts from a 4430 sitting in the shop. All snapped right where they neck down to splines
ccjersey
Posted 9/1/2024 08:56 (#10874469 - in reply to #10873799)
Faunsdale, AL
Any idea what got those?
blowsand
Posted 9/2/2024 21:37 (#10876508 - in reply to #10874469)
mercer county, il
One or two were a cv shaft on a mower conditioner, one was for sure. Pretty sure the other was a loose cv on the batwing.
Tomcat
Posted 8/31/2024 20:46 (#10874041 - in reply to #10873617)
Ludington/Manistee MI area
The Pretender - 8/31/2024 13:36 A place I worked once had a John Deere 3040 that snapped the PTO internally. There must have been a flaw in it, because it didn't have the grunt to snap a carrot in two.
Jockey in western Wisconsin sold me a tractor with the PTO shaft broken internally in 2 places.   He has a salvage yard also and wouldn’t even help me on parts.  I think he knew it and didn’t care.
Edited by Tomcat 8/31/2024 20:48
7110mag
Posted 8/31/2024 13:13 (#10873652 - in reply to #10873547)
Owens Cross Roads, AL
I broke the 540 shaft on my 7110 once with the 15' bush hog. I had the tractor in sharp turn when I engaged the pto and it broke the shaft. Wilson
illinois-kris
Posted 8/31/2024 14:01 (#10873707 - in reply to #10873547)
IL
If it isn't pretty straight when you kick them in at mid to high rpm they will snap pretty easy. Neighbors teenage kid found that out and keeps doing it so that he doesn't have to mow.
DougG
Posted 8/31/2024 15:43 (#10873808 - in reply to #10873707)
LOL,, I think you should set them down and tell them how to do their job,, LOL,, or just do it yourself maybe better
illinois-kris
Posted 8/31/2024 19:13 (#10873948 - in reply to #10873808)
IL
Not my kid, not my tractor, not my problem. Every time the neighbor complains I cut him off and tell him to do something about it.
jdbob8100
Posted 9/1/2024 09:36 (#10874510 - in reply to #10873808)
ND
Change yoke & get a tractor with a 1 3/4 pto. 12r 30 Loftness chopper, started with a Case 2590 with an 1 3/8 1000 pto & snapped tractor shaft upon start up, replaced shaft & when chopping again later when the chopper was running snapped again, hence switched to a 4650 Deere has 1 3/4 PTO.
Andy and John
Posted 8/31/2024 19:59 (#10873984 - in reply to #10873547)
i suspect your implement shaft is twisted and wont slide in and out,
John
Andy and John
Posted 8/31/2024 19:59 (#10873985 - in reply to #10873547)
John
roo
Posted 8/31/2024 21:14 (#10874083 - in reply to #10873547)
Cullom, Illinois
Not familiar with your tractor but could the pto brake be stopping the shaft too fast? Then the momentum of the mower is snapping it off. Perhaps they were shutting the pto off at full throttle and the pto brake stopped things instantly or at least tried too. Just a guess.
Tomwisc
Posted 8/31/2024 21:44 (#10874119 - in reply to #10873547)
What kind of hp is the tractor outputting? I know that
540 is good for about 125hp,
1 3/8 1000rpm is about 200 hp
1 3/4 1000rpm is about 400 hp
2 1/4 1300rpm is about 800 hp
You can swich to the large 1000 pto on the tractor you will loose the 540 rpm if you do this.
Dcil
Posted 8/31/2024 21:56 (#10874131 - in reply to #10874119)
I broke a pto shaft off a 7120 , I then replaced cvt on deere batwing. I think pto shaft wore on tractor then damaged cvt .
Hookerhill
Posted 9/1/2024 00:07 (#10874218 - in reply to #10873547)
NCMO
You might want to take a hard look at your bush hog cv joint, if it feels “sloppy “ it will break your tractor pto shaft. Last year 4430 deere snapped, our local welding shop has aftermarket cv joints at a fraction of bush hog, so far so good.
