Search Forums | Classifieds (54) | Skins | Language
Brent Grain Train 1000
   Forums List -> Where Can I find?????Message format
magnumman
Posted 6/30/2024 11:26 (#10793180)
Subject: Brent Grain Train 1000
NW Central Iowa (Fort Dodge)
I have been looking for one of these for about 2 years, anyone know of one located in/near Iowa? I found one a couple hours away but wanted a ridiculous price, it was like 8k and they still have it to this day.......
(BrentGrainTrain1000 (full).jpg)
Attachments BrentGrainTrain1000 (full).jpg (47KB - 340 downloads)
bulldog
Posted 6/30/2024 11:54 (#10793207 - in reply to #10793180)
Subject: RE: Brent Grain Train 1000
Why is 8000 a ridiculous price?
Glenn W.
Posted 6/30/2024 12:00 (#10793217 - in reply to #10793180)
Southeast Washington
I looked real quickly on tractorhouse and all I saw were smaller and more expensive. If you want it, get it.
We only use carts here and no wagons.
AGB
Posted 6/30/2024 12:06 (#10793224 - in reply to #10793180)
Mid-Michigan
Price doesn't sound bad. Are you sure you want that vs a cart? When that thing sinks, good luck.
tommyw-5088
Posted 6/30/2024 12:29 (#10793251 - in reply to #10793224)
Texas
Better put a decent horse in front of that , I know a 800 cart behind a 7140 was plenty. Of course my tractor is small by today’s standards.
Kooiker
Posted 6/30/2024 12:41 (#10793258 - in reply to #10793224)
AGB - 6/30/2024 12:06 Price doesn't sound bad. Are you sure you want that vs a cart? When that thing sinks, good luck.
They're completely different things.
A cart is used in the field for moving grain from the combine to the trucks or wagons sitting on the end of the field.
A wagon or truck is used to haul grain down the road.
If that wagon sinks, its because some idiot pulled it where it didn't belong.    Same as when a truck gets stuck in a field.
IMO, if its in good shape and you want one you better buy it.    There isn't many of them out there and $8000 doesn't buy much anymore.   Take a look at a new Brent 657 for ~$30k.     Wasn't that many years ago that a 644 was under $15k.    Not that much has been improved on grain wagons, just the value of the USD cratering.
AGB
Posted 6/30/2024 13:53 (#10793326 - in reply to #10793258)
Mid-Michigan
Yep. It's always easy to park on good solid ground. Very good point. Yet a cart can do all the things you mentioned. Not one. And they float on wet ground just in case "an idiot" happens to pull someplace other than the road.
Edited by AGB 6/30/2024 14:00
Kooiker
Posted 6/30/2024 14:12 (#10793354 - in reply to #10793326)
AGB - 6/30/2024 13:53 Yep. It's always easy to park on good solid ground. Very good point. Yet a cart can do all the things you mentioned. Not one. And they float on wet ground just in case "an idiot" happens to pull someplace other than the road.
Do you not use trucks to haul grain in Michigan?
AGB
Posted 6/30/2024 14:25 (#10793365 - in reply to #10793354)
Mid-Michigan
Yes. There are trucks here. And grain carts. Gravity boxes (have two 750 Brent's myself). So yes. A variety of vehicles to move grain.
Edited by AGB 6/30/2024 14:28
jd4930
Posted 6/30/2024 13:38 (#10793311 - in reply to #10793180)
Central ND
If there is none to pick from I would say the seller gets to determine what they are worth? What do you expect to pay for one?
magnumman
Posted 6/30/2024 19:18 (#10793752 - in reply to #10793180)
The wagon will never move from a auger, and its in very bad shape... tires are a time bomb......
AGB
Posted 7/1/2024 07:24 (#10794226 - in reply to #10793752)
Mid-Michigan
I would think using it as overload storage would work pretty good. I thought it was something you wanted to use in the field. I know I pull two 750 brent gravity boxes and you need to be very selective on where you park and load those things. I've also used one box just as you are planning and carted everything right to it if I was close to home.
Rowcropcattleman
Posted 7/1/2024 09:56 (#10794420 - in reply to #10793752)
Missouri
Those look like airplane tires, they’ll last forever, especially if you never move it loaded, they’ll still last forever even moving it up and down road with a load and cord showing.
Edited by Rowcropcattleman 7/1/2024 09:57
CMN
Posted 7/1/2024 13:30 (#10794657 - in reply to #10794420)
West of Mpls MN about 50 miles on Hwy 12
My thoughts as well. We had a couple A&L grain carts back in the late 70's early 80's with 34 ply, 250 MPH rated tires. They were pulled behind a tandem truck empty from MN to OK and back several times and carted quite a few bushels of wheat and corn in the field with little to no tread. I'm guessing the tires are probably still in use if the carts are still being used. Field floatation is almost nonexistent with airplane tires.
GrainTrader
Posted 7/1/2024 21:16 (#10795238 - in reply to #10793752)
20 Miles West of Indianapolis Indiana
magnumman - 6/30/2024 19:18
The wagon will never move from an auger, and its in very bad shape... tires are a time bomb......
Make em an offer. Worst he can say is no. Or maybe you already have?
We use a large wagon in front of auger also. I understand and appreciate the desire for a larger holding bin while the cart is off catching
Kooiker
Posted 7/1/2024 21:43 (#10795286 - in reply to #10795238)
Based off of the picture the OP posted and the picture in the link I'd think they'd be open to offers.
Spoiler alert, its the same picture of the same wagon, posted in 2011.
https://talk.newagtalk.com/forums/thread-view.asp?tid=204891&DisplayType=flat&setCookie=1
tmrand
Posted 7/2/2024 09:54 (#10795743 - in reply to #10795286)
Southeast Colorado
Hmmm............that's a little fishy.
magnumman
Posted 7/8/2024 21:36 (#10803467 - in reply to #10795286)
Yes that pic i got off the internet. as a example.
Boone & Crockett
Posted 7/2/2024 07:58 (#10795602 - in reply to #10795238)
GrainTrader - 7/1/2024 21:16
20 years ago I used a Lowery bin as a surge bin at bin site. Worked good, but I wasn’t dumping a cart into it. Think I paid $1,200 for it.
Expensive Hobby
Posted 7/2/2024 13:22 (#10795944 - in reply to #10793180)
NW Missouri
Well I'm with you - that sounds higher than heck for what it is. I know inflation is bad, but I sure wouldn't give that much just for an old junk wagon to park over an auger and dump into with carts (BTW, we don't have $8k in either of our 650 bu carts - a Kinze and a Brent). Sure, compared to new $30k wagons, $8k looks cheap, but to us poor guys that buy wagons off bigiron instead of the dealer, $8k sounds awful high. I'd let em keep it for that.
We have actually been looking for something smaller to do the same job - something in the 600-700 bu range. Doesn't have to be pretty, doesn't have to have brakes or a tarp, doesn't have to have good tires. Have passed on a couple in the 4-5k range. We'll find a good deal on one eventually. Till then we'll keep using the 400 bu wagon and unloading the cart a little slower.
Don aldG
Posted 7/3/2024 21:13 (#10797524 - in reply to #10793180)
Peoria,IL.
I have an old Brent with tandem rear wheels, uses hydraulic cylinder to open door on bottom. I think it holds about 600 bu. It needs repair from rust. Five tires look very good and 1 is older.
I will try to get it out next week. $1000 or best offer. Travels good.
3o964 8 972 seven
