Search Forums | Classifieds (75) | Skins | Language
Tordon 22K rate to spray fence rows and treelines in ATV sprayer ?
GrainTrader
Posted 6/13/2024 11:23 (#10773277)
Subject: Tordon 22K rate to spray fence rows and treelines in ATV sprayer ?
20 Miles West of Indianapolis Indiana
Trying to understand the label and not seeing what I think should be my mix rate. Seeing a spot spray label but not understanding it…
I’m going after general broadleaf weeds and any brush/small trees I can get. Would I be wasting money to add brush killer to it ?
Dave9110
Posted 6/13/2024 12:01 (#10773309 - in reply to #10773277)
Subject: RE: Tordon 22K rate to spray fence rows and treelines in ATV sprayer ?
north-central Indiana west of Fulton
It talks about 2.5 ounces per 4 gallons of water ….which I assume would work in an atv spraying. I use Tordon for stump treatment only. I use Crossbow or Crossroad when spraying what you are describing…..use a surfactant or crop oil with it . They say diesel fuel works , but I am kind of afraid of it damaging my pump, since I don’t clean out immediately after use.
GrainTrader
Posted 6/13/2024 12:17 (#10773323 - in reply to #10773309)
Dave9110 - 6/13/2024 12:01
This is a different formulation than the tordon we use on stumps.
Dave9110
Posted 6/13/2024 12:50 (#10773346 - in reply to #10773323)
2.5 / gallon of water is what was recommended for the 22k formula.
GrainTrader
Posted 6/14/2024 07:26 (#10774135 - in reply to #10773346)
Thank you.
money
Posted 6/13/2024 21:58 (#10773873 - in reply to #10773323)
east of indianapolis
beavertwp
Posted 6/13/2024 12:26 (#10773332 - in reply to #10773277)
East central Illinois
I used the bottom spray mix last year with excellent results.
The mixture is based on 100 gallons of water.
(Screenshot_20230531_111015_Samsung Internet (full).jpg)
Attachments Screenshot_20230531_111015_Samsung Internet (full).jpg (219KB - 76 downloads)
17821x
Posted 6/13/2024 15:37 (#10773477 - in reply to #10773277)
NE Iowa
My sprayer holds 75 gallon and used 0.75 gallon of Tordon 22k and 1.5 gallon of 2-4d lv4 per load. Tordon plus 2-4d is what grazon p & d herbicide is. My mix was replicating that and the use rate was based on that label.
Edited by 17821x 6/13/2024 15:40
RealFarmer
Posted 6/13/2024 18:49 (#10773636 - in reply to #10773477)
Marking ,,,,,,,,,,,,,
PTO
Posted 6/13/2024 20:35 (#10773743 - in reply to #10773277)
Northeast Misery
I use 3pt crossbow, 1pt tordon and crop oil in 25 gallon sprayer.
GrainTrader
Posted 6/13/2024 20:38 (#10773747 - in reply to #10773743)
Subject: What kind of results are you guys seeing using it?
What kind of longer term results are you guys seeing using the tordon rather than just crossbow?
17821x
Posted 6/13/2024 20:55 (#10773764 - in reply to #10773747)
Subject: RE: What kind of results are you guys seeing using it?
NE Iowa
I spray the Tordon and 2-4d mix along timbered fields every May to keep small trees and brush in check. If I spray it in a grass pasture it seems to take care of thistles and other weeds for 2-3 years. Tordon sticks around a long time. You never want to spray it anywhere you want to plant beans any time soon.
PTO
Posted 6/13/2024 21:09 (#10773784 - in reply to #10773747)
Northeast Misery
On locust and multifor rose, seems like not as many green back up the next year.
bspf
Posted 6/14/2024 05:38 (#10774043 - in reply to #10773784)
N.E. Iowa
cr39
Posted 6/14/2024 19:59 (#10774754 - in reply to #10773277)
1 quart (mason jar) of tordon 22k per 25 gallon spray tank.
dirtpour2
Posted 6/15/2024 18:15 (#10775637 - in reply to #10773277)
eastern Kansas
Mix some remedy and 2-4d with the tordon if you really want to kill brush
GrainTrader
Posted 6/15/2024 18:29 (#10775650 - in reply to #10775637)
What rate of remedy in a 25 gallon brew?
beavertwp
Posted 6/15/2024 21:46 (#10775848 - in reply to #10775650)
1 pt of Remedy (or Garlon) if you are using the Remedy/Tordon/ 2-4D/ crop oil mixture.
