Redwood Falls, MN | We have a Gleaner A65(Massey 9690), a 9795 and a 9545. We had a R62 Gleaner before the A65. When we were combine shopping back in 2009 or so we really liked the simplicity of the A65 and the ease of access to all the threshing components. While the R/S series Gleaner combines are quite simple with good capacity, we liked the single, wider feeder system, the lack of accelerator rolls, accessibility to the sides of the rotor. The 9675 will very likely have a smaller grain tank than a similar S Gleaner but unloading speed will be faster. Since we got the A65, we upgraded to a 9540 and now the 9545. They are simple, efficient machines and the SISU engines have proven to be very reliable and fuel efficient. We do our own fixing and really like the lack of moving parts on these machines vs a CIH or Deere of similar vintage. No shoe augers, no transition cone, easy access to everything mainly, intuitive grain flow from rotor to grain tank with minimal changing direction(improves grain quality), 1 cross-auger in the grain tank, etc. They do have some issues with tough, green stem soybeans but the ability to reverse the rotor usually allows you to unslug it from the cab by rocking it back and forth. Like mentioned, check for wear behind front beater behind feeder chain and look at the cascade pan to see if it's the updated perforated one. It's easiest to see behind the front beater by raising the feeder house, opening the rock trap and sticking your phone up to take a picture behind the beater. As for the cascade pan, the perforated one really adds to the capacity of the machine in corn really and allows the clean grain from the front of the rotor to fall directly into the clean grain auger and not run through the chaffer and sieve. Open up the side panels on the left side of the machine and its right there to see. We raise corn, soybeans for seed and cereal rye for grain. The nice part about the Massey vs the CIH you have for straw is the ability to roll back the chopper and not run it all through the chopper.
The A65 and 9795 are used mainly for soybeans, as we raise foundation seed for a company with 200+ varieties a year and need to cleanout between each one. While 1 machine is getting cleaned out, the other one is harvesting and just trade out the dirty one for the clean out and keep going. I also have a CIH 1660 and ran a 2388 and JD 9670 doing soybeans and would hands down prefer to own/cleanout the Massey designed machine for simplicity, grain quality and capacity. Sorry, that got long.
Edited by mrtiffany 6/9/2024 12:31
(20220921_191457 (1) (full).jpg)
(20210720_190003 (full).jpg)
(20210119_105552 (full).jpg)
(20210120_173648 (full).jpg)
(combining rye (full).jpg)
(FB_IMG_1650337305850 (full).jpg)
Attachments ----------------
20220921_191457 (1) (full).jpg (163KB - 60 downloads)
20210720_190003 (full).jpg (152KB - 75 downloads)
20210119_105552 (full).jpg (130KB - 66 downloads)
20210120_173648 (full).jpg (79KB - 68 downloads)
combining rye (full).jpg (185KB - 75 downloads)
FB_IMG_1650337305850 (full).jpg (147KB - 72 downloads)
