Search Forums | Classifieds (138) | Skins | Language
Home-made Bubble-Up auger pics
steve c-il
Posted 8/20/2009 22:38 (#818605)
Subject: Home-made Bubble-Up auger pics
Central Illinois
After discussion below, thought I would share pics of my Bubble-Up auger. Very simple project using stuff I had laying around.
(IMG_0500.JPG)
(IMG_0501.JPG)
(IMG_0502.JPG)
(IMG_0499.JPG)
Attachments IMG_0500.JPG (65KB - 717 downloads)
Attachments IMG_0501.JPG (62KB - 606 downloads)
Attachments IMG_0502.JPG (73KB - 670 downloads)
Attachments IMG_0499.JPG (57KB - 642 downloads)
msb
Posted 8/20/2009 22:41 (#818613 - in reply to #818605)
Subject: Re: Home-made Bubble-Up auger pics
Lapel, In
Looks good.
Buster 50
Posted 8/20/2009 22:42 (#818614 - in reply to #818605)
North West IA/western AZ
I don't see a drive. Is it hydraulic? I see it now, just posted too soon.
Edited by Buster 50 8/20/2009 22:43
mx240cb
Posted 8/20/2009 22:53 (#818639 - in reply to #818605)
Looks good. What are you tapping into for the hydrualic power? What kind of rpm does it run?
dave morgan
Posted 8/20/2009 23:31 (#818711 - in reply to #818639)
Somerville, Indiana
Only one problem, you are trying to take grain away from a left handed auger, with a right handed Bubble-Up. Won't work, a double negative.
jd9600guru
Posted 8/20/2009 23:48 (#818730 - in reply to #818711)
"Removed by admin" was Removed by admin
looks like it has been working........
steve c-il
Posted 8/21/2009 00:33 (#818765 - in reply to #818730)
Central Illinois
Used it 8 years on a 2366, on its 2nd season on a 2577. Have never slipped the clutch on grain elevator, or had to replace clean grain elevtor chain or inclined delivery auger. Probably should not have said that (knock on wood).
dave morgan
Posted 8/21/2009 09:51 (#818996 - in reply to #818765)
Somerville, Indiana
Had to tease a little. Looks like a good deal to me. I will copy that invention soon!
steve c-il
Posted 8/20/2009 23:36 (#818717 - in reply to #818639)
Central Illinois
Originally ran off hyd. reel circuit ( could adjust speed from cab) but would only run while feeder was engaged. I am now installing a CRARY hyd. kit for their rear spreaders that will let the auger run any time the seperator is engaged.
jd9600guru
Posted 8/20/2009 23:47 (#818728 - in reply to #818717)
It looks like a burvee bin fill auger to me.
http://www.burvee.com/bubbleup_auger2.htm
Edited by jd9600guru 8/20/2009 23:51
