Search Forums | Classifieds (1) | Skins | Language
JD 2955 hyd filter location
edbjd
Posted 1/29/2024 08:06 (#10598757)
Subject: JD 2955 hyd filter location
I’ve got a 2955 and I know where the transmission filter is located at the bottom of the rear end in the threaded spring loaded canister, but does anyone know if there is also a hydraulic filter anywhere on the tractor?
Mitchco
Posted 1/29/2024 08:22 (#10598784 - in reply to #10598757)
Subject: RE: JD 2955 hyd filter location
SW OH
Hydraulic and transmission oil are the same and that's the only filter it has. There is a suction screen in the bottom of the case like all other older Deeres.
Mitchco
KTA
Posted 1/29/2024 08:23 (#10598792 - in reply to #10598757)
There is a suction screen for the transmission pump behind a round plug right there at the filter cup location. Transmission pump flow is then through the filter to the transmission control functions (Hi-Lo and PTO) , then to the front high pressure  pump. No other replaceable filters. Normal service or problems?
edbjd
Posted 1/29/2024 09:52 (#10598919 - in reply to #10598792)
Thank you. Yes just normal service
kwswan
Posted 1/29/2024 09:54 (#10598922 - in reply to #10598757)
McMinnville Tn.
I don't know about the 55 series but on my 2950 there is a small inline filter on it. It's on the left side underneath the battery box.
560HighCrop
Posted 1/29/2024 11:28 (#10599051 - in reply to #10598757)
west central Iowa
Our 2955 with cab, has a screw on filter under front right corner of cab also. To the rear of the battery box. # AL56469
edbjd
Posted 1/29/2024 18:09 (#10599529 - in reply to #10599051)
Thank you!
edbjd
Posted 1/30/2024 18:04 (#10601029 - in reply to #10599051)
I looked on mine and cannot find anything anywhere that resembles an oil filter. I’m thinking mine just doesn’t have one. Maybe it was an option?
Lester563
Posted 1/30/2024 21:36 (#10601423 - in reply to #10601029)
Midwest
Suggest looking at an online parts catalog or pics of that model for sale that might show it.
