Maggies - 11/2/2023 19:56
twraska - 11/2/2023 19:18
Maggies - 11/2/2023 18:53
twraska - 11/2/2023 17:08
Maggies - 10/31/2023 21:25
Increased angle does not penetrate more less angle does. The disk blade smearing ground at the bottom of the blade is what creates the compaction when the soil dries. Same theory as sidewall compaction with a corn planter. Tillage compaction is not from packing ground it’s from smearing sideways.
You’re wrong
Ok please explain though, people will take you serious then.
Read the post from drester, he is correct.
I don’t know if any agriculture disk that reverse the angle on the disk so the convex side is in the ground and is packing their fields? When construction companies want to pack ground around here they use a packer?
Not saying construction companies don’t have a disk like this maybe in your area they do but farmers don’t. On our excellerator vertical till disk you can adjust the gang angle from 5-1 degree. If you want to sink it the deepest you put it at 1 degree. Dragging a knife straight will penetrate easier that dragging it sideways. My 2 cents from personal experience with multiple different tillage tools and agronomy trials
