Search Forums | Classifieds (4) | Skins | Language
21-22’ Wilson pup hopper bottom capacity ?
Lone Wolf Picker
Posted 10/14/2023 12:09 (#10440342)
Subject: 21-22’ Wilson pup hopper bottom capacity ?
Black Hawk County, IA
Been looking for something to pull behind one of my triaxles for extra grain capacity. The post below get me thinking about a hopper pup. Brent wagons seem expensive for what you get. Pup would have real brakes, and not as tall either. Question : how many bushels can I reasonably get on those hoppers ?
Maybe Downsizing will see this and respond. TIA J
Patriot81
Posted 10/14/2023 12:21 (#10440358 - in reply to #10440342)
Subject: RE: 21-22’ Wilson pup hopper bottom capacity ?
Farmington, Mo
I can't speak for the Wilson trailer but we have a 20' Doonan we pull behind our Mack grain truck that would be pretty similar. Works well except for how low the hopper is to the ground...makes it interesting pulling over the swing hopper auger if the location is a little uneven. it will easily hold 30000 lbs of beans or corn. Routinely get 35,000 lbs of corn and no more than 30,000 lbs of beans on a load...trailer is rated at 40,000 and weights about 6800.
We load it full most often than not so the truck doesn't have to be overloaded and still get 950-1100 bushels per load from field to binsite.
Our truck really needs a bigger engine to run like this in our hills but it handles the weight just fine...slower than a big block but we get home every load.
jd8850
Posted 10/14/2023 16:08 (#10440690 - in reply to #10440342)
Roseglen, North Dakota
To be technical wd be 4-5 sidewall heights which wd vary it.
Downsizing
Posted 10/14/2023 16:32 (#10440725 - in reply to #10440342)
21 FOOT Wilson will hold 500 bu of Corn
