Search Forums | Classifieds (110) | Skins | Language
Gated Pipe ??
Jeff Outwest
Posted 5/10/2023 19:12 (#10224131)
Subject: Gated Pipe ??
Janesville Ca, 96114
Does anyone irrigate pastures or fields with pipe like this?  How does it stay together?Joints of 8
cah
Posted 5/10/2023 20:45 (#10224236 - in reply to #10224131)
Subject: RE: Gated Pipe ??
Western Nebraska
Weight. Stays together.
Stiggy in Idaho
Posted 5/10/2023 22:27 (#10224410 - in reply to #10224131)
Buhl, Id.
Just shove them into the bell end just pass the gasket. Stake them down when there is no water in them. The wind has been known to move them around.
Hayinhere
Posted 5/10/2023 22:29 (#10224411 - in reply to #10224131)
Central NE
pastures, no,
30 or 36" ridged row crops, yes
never close all the gates with the well on. there is never any pressure in the pipe.
notillmc
Posted 5/11/2023 11:18 (#10224910 - in reply to #10224131)
SW TX PANHANDLE
If you need more there are piles of that around here. Although most need new gates and probably getting brittle. Been sitting for 25+ years!
silagehauler
Posted 5/11/2023 14:37 (#10225144 - in reply to #10224131)
Yep. Just the weight of the pipe and the friction of the bell and spigot joint kept things together. Always drove a t-post at the end cap and 2 posts at a tee or elbow.
berggrenfarms
Posted 5/11/2023 15:30 (#10225190 - in reply to #10224131)
Nebraska, The land of corn and cattle
You can clamp them together with clamps if you have lots of pressure, but usually we just let friction and its own weight keep them together, drive a t post on the end and it wont go anywhere
