Gramoxone , Spray Tips and Carrier
clayball farms
Posted 4/29/2023 19:40 (#10208784)
Subject: Gramoxone , Spray Tips and Carrier
Cen Ks
What is the NAT approved spray tip for spraying Gramoxone ? Any preference on using COC or MSO ? Will be using water as carrier, how many GPA carrier? Any special considerations if spraying small weeds early when its cool or late season and big weeds ? TIA
ObSeRv
Posted 4/29/2023 20:10 (#10208837 - in reply to #10208784)
Subject: RE: Gramoxone , Spray Tips and Carrier
If you have dicamba tips from soybeans, use those. Sure helps with bowling ball sized droplets if you’re concerned about what borders ya/etc.
ksufearless
Posted 4/30/2023 12:40 (#10209816 - in reply to #10208837)
NW KS
ObSeRv - 4/29/2023 20:10
is no drift or killing weeds your goal? those tips do a TERRILBE job, allowing the drops to roll off the leaf. Med course to fine droplets will kill better, but will drift if allowed. spray in 2-5 mph wind, in a direction of a non crop. if you cant do that, you likely will not succeed.
ObSeRv
Posted 5/1/2023 08:08 (#10211062 - in reply to #10209816)
Drift is as important as killing weeds. I’m not an asshole to my neighbors; maybe you’re known as “one of them”.
Full rate of chemical, using those tips with enough gallonage you won’t have a problem. Happy spraying.
AR Plowboy
Posted 4/29/2023 20:44 (#10208898 - in reply to #10208784)
East Central Arkansas
This year I ran the Greenleaf TD 11004 tips at 15 GPA. I use surfactant and a couple Oz of metribuzin where the crop allows.
(20230428_094204 (full).jpg)
Attachments 20230428_094204 (full).jpg (100KB - 62 downloads)
indeed
Posted 4/30/2023 07:02 (#10209233 - in reply to #10208784)
I always use a tip with medium to course droplets and a NIS. Coverage is key with gramoxone. If there is any concern with physical drift you can run drift reducer like interlock.
Triticum Agricolam
Posted 4/30/2023 09:52 (#10209558 - in reply to #10208784)
Eastern Washington State
You need good coverage, you can get that will a smaller droplet size and less GPA (though this is more prone to drift) or a larger droplet size and more GPA (more of a logistical challenge).
I've been using Greenleaf Airmix nozzles at 11-12 GPA and ~60 PSI, these work well for me. A TeeJet AIXR would be very similar.
As far as mixes go, I use crop oil and I add 3 gals/100 of UAN. I think the UAN is very important. I feel Gramoxone works best when its hot and dry. I've had plants grow out of it when I got a rain and cool days a couple days after spraying.
ady5008
Posted 5/2/2023 12:18 (#10213011 - in reply to #10208784)
Central PA
It's not what's recommended but I've never had a problem getting a kill with AI nozzles and really haven't had a problem with drift either. Normally run 18-20 GPA.
