Between Omaha and Des Moines, 7 miles South of I80 | Here's an older thread, about implement switches, with some part numbers, too. ( I run 2 switches, with them wired in parallel = if one row unit, dropped on a hole, the circuit still is alive, due to the second implement was still active)
https://talk.newagtalk.com/forums/thread-view.asp?tid=546103&DisplayType=nested
Doesn't take too much room, to calibrate the SteadySteer = think a bit larger area, where the tractor can perform its own "figure 8" pattern ( I did it, in the corner, of a cattle pasture)
When I installed the SteadySteer anti-rotation bracket, in my JD4440; I wasn't happy with Ag Leader's clamp style, to go around 4440 steering column/tube = I added a 2" muffler clamp, underneath with a couple little welds, to Ag Leader's clamp, and that muffler clamp holds VERY well.
Did you get a Engage/Disengage foot pedal and/or momentary switch, to control the autosteer function? {note: I found, last June, during replanting of my hailed soybeans, that "pushing the screen icon" for autosteer, and bouncing in the tractor, I would sometimes "Double-bump" the icon, using just the screen/monitor {= I have since added momentary switches and wires going to terrain compensation controller to give me a better control, for engage/disengage function = this should help me, I hope}
I did use WAAS, during the replant of soybeans, BUT that wasn't a critical planting either, at that moment, because some of the damaged soybeans, would/did come back. I have since upgraded the TerraStar-C Pro , on of my GPS7500 receivers, ($2000 unlock fee) and will buy the 4 month yearly subscription, around April 15th, for $825.
Note: Ag Leader will give you a free 5 day trial period, before you buy TerraStar-C Pro = I used that 5 day trial peroid, to go around, in December, to make new Outer and Inner boundaries ,in all my fields {Erased old WAAS boundaries, before hand; as I was pretty sure I was going to spend the $2000 unlock fee, for the upgrade, for planting this coming Spring 2023}
Edit: You didn't mention about any row shutoffs, but make sure your measurements are correct for GPS Globe, 3 point, drawbar hole, distance of planter's hitch hole to seed drop area = maybe your installer did this, doesn't hurt to verify either.
You could add your seed corn number and soybean numbers, into the products area, ahead-of-time.
Edited by 4WD 3/3/2023 09:11
(DeerePlanterSwitch (full).jpg)
Attachments ----------------
DeerePlanterSwitch (full).jpg (32KB - 148 downloads)
