Spray boom end cap
Riverwood
Posted 2/20/2023 06:52 (#10103332)
Subject: Spray boom end cap
Hanby Mill, AL
Replacing piping on my 80' spray boom and want to add end cap flush valves. Looks like there are at least 3 options with Hypro, Pentair, and Wilger. I'm looking for recommendations for these or others.
My understanding is that some (or all) of these also work as a vent that result in better sprayer performance by eliminating air in boom? Any advice from someone with experience would be appreciated. Thanks
farmerlion
Posted 2/20/2023 07:46 (#10103402 - in reply to #10103332)
Subject: RE: Spray boom end cap
We have the wilger ones and really like them. But they do not have an air vent if thats what you want
Riverwood
Posted 2/20/2023 08:02 (#10103424 - in reply to #10103402)
Hanby Mill, AL
If they work as advertised I'd like to get the vented valves
bmatteson
Posted 2/20/2023 10:10 (#10103597 - in reply to #10103424)
NEND
I have the Hypro Express end caps. I like them, they do let air out. They now have the option to be equipped with valves to drain them out. I had to buy those separately because they didn’t have the option when I bought the original end caps. How much are the Wilger ones? They look like a good deal just for flushing. But if the Express endcaps aren’t much more total investment (depending on how many you need), I’d get the Express endcaps. Another advantage of the Express endcaps is the don’t have the dead end space at the end of the boom/past the last nozzle body like any other end cap would have. The one thing about the express endcaps is they are more time consuming to install, and you need a special jig to drill the holes for them (it was a little over $100 when I put mine on.
dk77
Posted 2/20/2023 12:49 (#10103793 - in reply to #10103597)
NW Iowa
+1 to bmatteson's post. I started wth the Hypro express caps and added the 1/4 turn valves when Pentair came out with them. There is one spot on each boom of my 4710 where a cross brace is in the way so the valve can't be installed.
WilgerIndustries
Posted 2/21/2023 09:19 (#10105008 - in reply to #10103424)
Ah, thats the newer flush valve version.
He's talking the valve that incorporates the last nozzle body at the end-most part of the boom, has a full volume air purge through that last body, and has the full ID flush valve directly below. It also has a port above for recirc kits, if needed.
(CRBEFV_infographic2 (full).png)
(Pipe End Options (full).png)
Attachments CRBEFV_infographic2 (full).png (97KB - 23 downloads)
Attachments Pipe End Options (full).png (140KB - 27 downloads)
tedbear
Posted 2/20/2023 08:07 (#10103431 - in reply to #10103332)
I had a Fast 3 point sprayer and they just used Garden Hose Caps at the ends. I was able to install/remove them by hand. This might not be as convenient but it seemed OK for my purposes.
dvswia
Posted 2/20/2023 08:10 (#10103440 - in reply to #10103431)
sw corner ia.
quarter turn valve will work without getting stuff all over your hands
tedbear
Posted 2/20/2023 08:33 (#10103475 - in reply to #10103440)
dvswia - 2/20/2023 08:10
I suspect the reason that mine came with Garden Hose Caps was cost. As I recall my boom had nine or ten dead ends. The cost of that many quarter turn valves would add up.
Edited by tedbear 2/20/2023 08:52
dvswia
Posted 2/21/2023 06:02 (#10104759 - in reply to #10103475)
sw corner ia.
I think my body is worth that..
mdnelson86
Posted 2/20/2023 12:51 (#10103796 - in reply to #10103332)
Paxton, IL
I had the Wilger flush valves on my sprayer. Ran I think 3 seasons like that, they will gradually get harder and harder to turn, then last year I started having trouble with a bunch of them leaking pretty bad. Took them apart and the O-rings were all shot. The o -rings can be replaced, but I decided they were more of a pain than I wanted to deal with after a couple seasons again. I ended up switching them out for banjo 1/4 turn mini ball valves. I only used them when cleaning the sprayer out last year, so don't have much experience with them yet. So I far I like them a lot better than the Wilger's though.
As far as bleeding air, I just go back and crack each valve to purge any air after I run the boom dry (which I try not too do too often. Usually only when cleaning out and switching products). An automatic way to purge air would be handy, but not bad to do it the way I currently do.
farmcdc
Posted 2/20/2023 20:46 (#10104447 - in reply to #10103332)
Fremont, NE
I use natural gas/propane 1/4 turn valves from Bomgaars then just added a poly 90 degree elbow and point it where you want. Have worked great for 3 years now and no issues with hard to open or leakage. I just crack open for few seconds to purge any air like stated previously. Much cheaper than branded flush valves.
Jacob Bolson
Posted 2/22/2023 08:30 (#10106467 - in reply to #10103332)
Iowa
Riverwood - 2/20/2023 06:52
Pentair = Hypro's parent company.
