Search Forums | Classifieds (12) | Skins | Language
Ford 8830
TXrancher45
Posted 11/12/2022 15:34 (#9928151)
Subject: Ford 8830
Does anybody know how the intercooler system works on this tractor ? Is there a separate fan in the housing pulling air from left side of tractor, or is this all run off of the turbo ? Can’t seem to find any info…. What are common issues that could cause the intercooler to not work ? Thanks !
Bern
Posted 11/12/2022 17:10 (#9928256 - in reply to #9928151)
Subject: RE: Ford 8830
Mount Vernon, WA
A separate "tip turbine fan" is used to route cooling air through the heat exchanger. Approximately 10% of the turbo output is used to drive said fan. How do you know it doesn't work?
(IMG_8929 (full).JPG)
(IMG_8928 (full).JPG)
Attachments IMG_8929 (full).JPG (195KB - 71 downloads)
Attachments IMG_8928 (full).JPG (83KB - 78 downloads)
TXrancher45
Posted 11/12/2022 18:05 (#9928343 - in reply to #9928256)
Hello Bern, thank you for the info. I don’t know that it doesn’t work. I’m doing some minor seasonal repairs and just realized that I’ve never serviced this part of the engine… ever … so I’ve been looking at it trying to first figure out how it worked, then if anything associated with it needs to be addressed or serviced. I mean - in 30 years it hasn’t been touched !
Bern
Posted 11/12/2022 20:06 (#9928549 - in reply to #9928343)
Mount Vernon, WA
The next time you have it under a hard pull, open up the RH door and feel for hot air coming from the RH grille screen. A blast of hot air means it's doing what it's supposed to. No air movement likely means the turbine and/or aftercooler is plugged with dirt.
TXrancher45
Posted 11/15/2022 15:04 (#9933379 - in reply to #9928549)
Hey Bern….. I have the intercooler unit taken out of the tractor and disassembled. Radiator was definitely dirty, and a lot of dirt came out the left side air intake large assembly. The turbine seems to spin freely. My question is, is there any maintenance to the turbine that I should do while I’m at this point ? Can you re grease it ? Looks like the shaft is permanently set in a cast iron housing. It’s a real pain getting this far in, so I figured I’d ask because I don’t want to get back in this far for long long time ! Thanks !!
Bern
Posted 11/18/2022 21:04 (#9939016 - in reply to #9933379)
Mount Vernon, WA
If the turbine spins freely I'd leave it alone. I believe it runs on a sealed bearing that is not designed to be serviced.
