Columbia Basin, Ephrata, WA | slewis - 8/28/2022 19:18
Letting it idle through the tough spots is exactly how we make it up. It basically loose rock on rock so there's no grading to be done. Hauling gravel in would make it worse. I have heard of guys leaving grain in the hopper. I guess my issue is I only have one hopper so I'm not sure leaving grain in it would get much weight over the drive axles but maybe it would. Adding lockers is definitely an option. and maybe I'd do that before swapping trucks.
That would be some real low quality gravel if it makes it worse. It has to be crushed and it needs fines.
I have a couple of trucks with lockers. They might help a little, but like someone else said, they don’t help as much as you’d think they would.
