 Ripley, Ontario Canada | It is the same as an 8610 only turbo'd. The general recommendation is to run fast and far away. These tractors give trouble, I had to do an engine, major transmission work and had transmission sections start to come apart before 3600 hours on a 6105 white which is the same tractor only with a water cooled engine. If you buy it needs to be real cheap, and not your main tractor. | |
