Kingston,Mi | A quick search for USED combines on Tractorhouse with the following parameters: 1990 to 2000, $25000 to $50000, John Deere, CIH, Gleaner and Massey in Michigan, Ohio, Indiana and Illinois found 216 machines from as large as a 9750 to as small as R42. I would think that all the equipment dealers would want to be as little wet from taking a bath with this operation so renting on a per hour basis with the payments coming weekly from the receiver.
One of the AGCO dealers in that area rented used equipment they owned that was in inventory when they were John Deere dealers, if wasn't being prepped for resale, it was available to rent. That way it was earning its keep, I rented a nice 7720 to harvest 20 acres of soys once and understand that an acquaintance once had 4 or 5 JD 95's running together in one field in the late 60's. The family owned 1 machine possibly 2, the rest were from the dealership. If you wanted to see them run, they took you to the field, if you bought, they unloaded and handed it over to the new owner. | |
