![](/images/spacer.gif) | |
Oregon | I suspect the check valve, but this thread identified the piston stop as the culprit in a similar fact scenario. Dry firing will destroy the stop- but I still suspect the check valve.
See: http://www.diychatroom.com/f29/porter-cable-nail-gun-not-retracting...
I also copied this from anther thread that repeats what others have shared about oil and a couple of other things:
There are two separate failures that could cause a similar symptom description.
1) The driver is fully extended from the nose and does not return upward at all, unless the air supply is disconnected from the tool. Check that the driver is straight and that there are no interefence inside the nose channel.
2) The driver returns, but only partially, not enough to allow fasteners to advance. This usually suggests sluggishness, due to lack of lubricant, worn o-rings of the driver piston and bumpers. A complete rebuild with the appropriate parts would be the best option. Individual parts to be considered are:
A) lower o-ring of the cylinder
B) o-ring on the driver piston
C) bumper
-Mike
