East Central Saskatchewan | Agree with others. Aluminum ramps seem to have to much of a tendency to break. Anyone around here who has had aluminum ramps either broke them or bent them. They got tired and went to steel, more heavy and expensive, but much safer if built correctly. Also have to remember when buying, you can't just buy ramps according to machine weight if they are close to total capacity, but operators weight on that as well (unless you have a way of getting something on without anyone driving it). I found mostly heavier set guys had trouble most often. Steel ramps aren't very hard to build either. |
