Search Forums | Classifieds (5) | Skins | Language
Honda Rancher wont start
Plierswearer
Posted 8/11/2017 21:49 (#6181601)
Subject: Honda Rancher wont start
Midwest
Last night I went to start my Rancher 420, it started fine, but I thought to myself the starter made a different noise. I rode it a bit, shut it off, and all it would do was click at the solenoid. So, today, I bought a new solenoid, put it on, and it still will only click. Battery is good. What now?
mignic
Posted 8/11/2017 21:52 (#6181609 - in reply to #6181601)
Subject: RE: Honda Rancher wont start
Texas Panhandle
The grounds have been a problem on ours. Don't remember which specific one but has been several times.
fredro1
Posted 8/11/2017 21:55 (#6181616 - in reply to #6181601)
Southeast Missouri
Had a friend with the exact problem. It was the brushes in the starter. It's a common problem. It only cost him 42 dollars at a starter repair shop.
DieselDennis
Posted 8/11/2017 22:49 (#6181729 - in reply to #6181616)
Brandon, MS
+1
You can buy a brush kit for about $15. Not that hard to install.
ndsu84
Posted 8/11/2017 22:04 (#6181633 - in reply to #6181601)
EC North Dakota
Plierswearer - 8/11/2017 21:49
We had to take the starter out and free it. Put it back in and it's been working since.
gene_champ
Posted 8/11/2017 22:09 (#6181640 - in reply to #6181601)
NC Iowa
On my pioneer, the magnets came loose in the starter. Just out of warranty. Bought aftermarket starter on eBay for about $50.
roush9799
Posted 8/11/2017 23:03 (#6181746 - in reply to #6181601)
West Central IL
Starter brushes, Change them all the time on our Hondas. Not sure on your year, but you need probably #2 and #3. Once you have the starter off you can change them in under 10 minutes with a small socket set. Here's the link to the starter breakdown http://www.cheapcycleparts.com/oemparts/a/hon/53f21b55f870021c8062d...
AR Plowboy
Posted 8/12/2017 07:00 (#6181936 - in reply to #6181601)
East Central Arkansas
On our Foreman 500's I have had the starters lose ground. I had removed starter and checked it off of the engine and it seemed to work fine so reinstalled and it worked good. I don't remember if it was a ground wire or if I just cleaned the mounting surface.
farmdude
Posted 8/12/2017 08:08 (#6182063 - in reply to #6181936)
One thing thats nice when you have a pull starter as well as the electric one your never stranded.
AR Plowboy
Posted 8/13/2017 14:16 (#6184334 - in reply to #6182063)
That is if you are man enough to pull the one on a Foreman 500. That thing can really jerk a kink in you.
KRMN FARMN
Posted 8/12/2017 08:18 (#6182078 - in reply to #6181601)
Central nebr
My 2015 rubicon did that. Only 1000 miles on it. The starter magnets came apart. New starter fixed that
