gene_champ - 11/23/2016 10:14
nekfarmer - 11/20/2016 19:36
Nicktane (many others to copy) is what would get my vote. $100 or less for the set up and you can get cheaper and better filters. For the guys running a cat filter you have to remember you've lost your water separator. On my truck I added a second filter housing on the frame rail (before my aftermarket lift pump) that I put a true water separator on. Donaldson makes a fuel/water separator with a 2 mic rating. Water will wreck a fuel system as fast or faster than dirt.
Did you cut the hard line after the cooler for the filter head, or run a new line? I am trying to figure out how to plump everything in.
