Posted 9/2/2016 18:32 (#5505743) Subject: What kind of long lasting lube for squeaking tractor seat?
North Central Alabama
I have a couple of cab tractors with suspension seats.Every time I get in and drive them seems like the seat suspension sqeaks.It drives me crazy.I keep a can of Walmart spray lube in the cab.I have to lube the moving parts every day.What kind of lube would hold up longer?
Posted 9/2/2016 19:59 (#5505887 - in reply to #5505743) Subject: RE: What kind of long lasting lube for squeaking tractor seat?
Ontario
not sure how well it'd work but honey goo is very sticky. as a side benefit it also smells pretty good. not cheap tho, think last i saw it was $12 a can here
Posted 9/2/2016 21:15 (#5506037 - in reply to #5505743) Subject: RE: What kind of long lasting lube for squeaking tractor seat?
Tx
Try some Liquid Wrench chain and cable lube. It dries after you apply it so it doesn't attract dust. I also use it on the door latch mechanism on our 4840. Sure helps everything slide better.
Posted 9/3/2016 03:15 (#5506297 - in reply to #5505743) Subject: RE: What kind of long lasting lube for squeaking tractor seat?
West Union, Illinois
Our Case 9270 had a Sears seat. After a few years it started to squeak. I bought a rebuild kit through Case, which did no good. The final solution was removing the seat and mounting it on a replacement pedestal from ... I think it was A & I.
