Search Forums | Classifieds (52) | Skins | Language
Adjusting bale length on 273 NH
tractormiallis
Posted 7/28/2016 07:32 (#5436613)
Subject: Adjusting bale length on 273 NH
W. Michigan
How do I adjust bale length on a 273? I'm thinking it must be adjusting when to tell it to trip knotters, but I don't have a manual get so I'm not sure. It's making the bales short, need closer to 42 inches. Thanks
IAGary
Posted 7/28/2016 08:17 (#5436681 - in reply to #5436613)
Subject: RE: Adjusting bale length on 273 NH
Southeast Iowa
The trip arm that activates the knotter has a ring on it with a set screw.
Move that ring higher to allow the arm to drop down farther.
Number twelve in the picture below.
http://partstore.agriculture.newholland.com/us/TitanMachineryAlbert...
Edited by IAGary 7/28/2016 08:24
Kooiker
Posted 7/28/2016 08:18 (#5436684 - in reply to #5436613)
The flat metal piece that is kind of a "J" shape trips the knotters when it is time to tie.
There should be a little piece that clamps on that piece with a set bolt.   You need to slide the clamp up higher to make the bale longer.  It doesn't take much movement to make a sizable change in bale size.
Hay Hud Ohio
Posted 7/28/2016 13:41 (#5437192 - in reply to #5436613)
SW Ohio
And be sure to tilt it clockwise as you stand on the non pickup side of baler or else it will turn itself when it falls back down.
patiently awaiting your next question because with a 273 there WILL be more questions........
17821x
Posted 7/28/2016 19:21 (#5437644 - in reply to #5436613)
NE Iowa
Your baler better not have a thrower because 42" bales and a 273 with a thrower won't work.
