Clear Lake, IA | Quick history of my machines: Bobcat 542b, Bobcat 773, Bobcat 873, Case 95XT, Bobcat S300, Cat 277C, Case SV300, Bobcat T320. Some of these I owned and others I ran for employers. You asked about the Case so that is what I will address. My SV300 had EH controls and that was the major downfall of that machine. No matter where you had the controls set in the corner post they had no feel and were very unpredictable. They also have very poor ground clearance and got stuck a lot. Machine has good visibility, way more power then traction, ok cab, and decent stability under heavy load. The door on the Case in my opinion opens the wrong direction from the rest of the industry. If you have a attachment with hoses the door opens so you have to crawl over or around them. Case has a long way to go as far as cab and creature comforts. I have found that a track machine is what I need for what I do.
(IMG_3180.JPG)
Attachments ---------------- IMG_3180.JPG (140KB - 65 downloads)
