Faunsdale, AL | It works just fine, but you will get better performance on converted automotive R12 systems if you don't charge it until you completely clear the sight glass. I think the 134a really needs a bigger condenser and evaporator than R12. Seem to get the coldest air when low side runs about 22 psi. This is most noticeable on orifice tube systems with a low side switch controlling the compressor clutch. These are very sensitive to overcharging. Also note that many of the low side switches are adjustable. if you take the wire plug off, there is a screw between the prongs of the switch to adjust the cutout pressure.
Expansion valve systems experience a much slower degradation of performance as you overcharge. Essentially as you overcharge it, you are filling the condenser with liquid refrigerant which can be subcooled, but this is a minor refrigerating effect in the whole system compared to the major effect of condensing and evaporating. Usually you want to have there be just enough refrigerant in the system that there is enough liquid refrigerant coming from the condenser to the expansion valve to keep up with the rate of evaporation in the evaporator. With 134a in a converted R12 system, and the evaporator being a little small , it helps a little to artificially lower the temperature in the evaporator by slightly undercharging. | |
