Posted 7/14/2015 20:52 (#4680085) Subject: Gas can spout
So. IL
Anyone know a good source to purchase gas can spouts that fit on the 5 gallon plastic cans? We have some of the auto on/off spouts and they are garbage, takes 10 min to dump a can and half ends up on the ground. Tried the ez pour replacements, and they don't last very long either. It's apparent the epa has never tried to use one of the latest and greatest cans they think we must have. Thanks
Posted 7/14/2015 20:56 (#4680095 - in reply to #4680085) Subject: RE: Gas can spout
NWMO
I just use them as caps, I take them off and use a regular funnel. I agree they are junk. To answer your question I do not know where to get good ones sorry.
Posted 7/14/2015 21:06 (#4680118 - in reply to #4680085) Subject: RE: Gas can spout
Hazelton, Kansas
Eric,
Someone mentioned the NoSpill cans here on NAT a while ago. I think I have three of them now. IMO, they're pretty good...not perfect, but the best I've seen for sale recently.
You will quickly see how to make them less annoying and more safe, with about 30 seconds work with a side-cutter.
Posted 7/14/2015 21:28 (#4680191 - in reply to #4680176) Subject: RE: Gas can spout
Northeast corner of Clark Co. Missouri
Add a vent to the ventless cans by drilling a hole where the vent should be and inserting a tubeless valve stem without the core. Just unscrew the cap and now you have one that empties quicker.
Posted 7/14/2015 21:32 (#4680208 - in reply to #4680191) Subject: RE: Gas can spout
WI
NEMOcattle - 7/14/2015 21:28
I used to do that. the problem is the gas would eat away at the rubber valve stem.
Posted 7/14/2015 22:35 (#4680399 - in reply to #4680168) Subject: RE: Gas can spout
I have three 5 gl plastic fuel cans that I have put those spouts one. They come with a vent plug a s well. Have had them 3-4 yrs & no problems so far. Have a 4th one hanging in the shop in case I ever need another one.
Posted 7/14/2015 21:47 (#4680256 - in reply to #4680085) Subject: RE: Gas can spout
nc IA
No more plastic JUNK.
Only NATO STEEL cans for me from here on. They'll last my lifetime, and keep the gas in better condition since they don't breath like a plastic can does. and they empty out better then the new plastic garbage.
Posted 7/14/2015 22:48 (#4680435 - in reply to #4680256) Subject: RE: Gas can spout
FFJR - 7/14/2015 21:47
+1000000
Nearly had a tragity due to plastic cans. Junked them and steel safety cans from now on.
I use this for diesel, the sections screw together and its like 5/8" flow. Just remember to put the vent cap in too. Its got a cap to keep dirt out of the spout too.
For gas, they sell the dinky single section with a small end that will fit in the undersized gas cap in a gas vehicle.
Posted 7/15/2015 06:48 (#4680668 - in reply to #4680085) Subject: RE: Gas can spout
Midwest
I Quit using the spouts and now use this siphon hose http://www.amazon.com/Super-Siphon-Hose-Pack/dp/B000ZORJ1E It works great, really fast if you elevate the can. I need to know where to find a gas cap without a spout. Just a cap.
Posted 7/16/2015 16:09 (#4683316 - in reply to #4680085) Subject: RE: Gas can spout
Davison, Michigan
Menards in our area has replacement spouts amid vents. I changed all mine. I have also seen a video somwhere of a guy who drills back of can and installed a valve stem in hole, take the core out then loosen the cap as a vent
