I'm in the process of building a new cage free chicken house. My designer is from Buffalo, MO and says that the foil dbl. bubble on both sides of the wall would be adequate. In SE IA people have not really been using that and not sure if it would be adequate. My biggest concern would be to keep the inside walls from "sweating". I will have several heaters to provide supplimental heat and lower the humidity. The chickens will actually provide enough body heat to keep it warm as my current building is curtain sided at the top 3' and I use no additional heat but it is very humid and some walls with blown in insulation get real wetwhere the insulation settled. This will be an enviromentally controlled building. Would it cost less or more then conventional insulation? The inside wall will be lined with something other then steel on the bottom 1/2. Any tips and advice would be appreciated! |
