![](/profile/get-photo.asp?memberid=1306&type=profile&rnd=709) central - east central Minnesota - | Maizeing - 4/22/2013 13:16 You guys got any experience with excavator mounted drum style shredders? Been looking at a few, the Bauma Light Brushfire, Pro mac etc. Some of them drums are ok for stones, I'm thinking thats a must for us. Anybody got any good/bad experience with any make? Some are flails, some fixed teeth, they all look pretty horny but I want one that won't fly all to he(( the first time we hit a stone.
If you are comparing a drum style to a rotary blade type cutter - I'd suggest trying (renting?) one of each, for your intended use. I rented a carbide drum cutter for some heavy duty thick big trunk type brush and small trees. . . . I was very disapointed and glad I rented before buying. A buddy of mine bought a blade type cutter with exposed blade on front and it'll out cut the drum cutter almost 3 to one. It does a better job of shreading and multching then the drum style also. Think of the drum style as a stump chipper . . . . . if the trunk is large enough and stuck in the ground, it works well. When the trunk is cut off or broken off, then trying to get it to multch or chip is very time consuming and hard to do, as the brush/trunk move when the head hits it. Look at these examples from Brush Wolf Mfg - http://www.brushwolf.com/showcaseproductlist.htm I do a lot of skidsteer brush cleaning every yr - the rotary bush cutter is my tool of choice, for shreading and multching.
Edited by iseedit 4/22/2013 13:33
