 Woodham, Ontario | Yes they can work together, but the steering always has to stay on the 2630. Planters, aircarts, rate controllers and SF3000 receivers can be displayed on the command center or on 2630.
This is my planter setup: I have the autosteer and 1910 aircart on the 2630 and the SeedstarXP on the commandcenter
The 3000 receiver sometimes goes from one to the other. The planter and aircart don't move unless I tell them to go to the other display. You cannot display them on both screens at the same time and the command center only works in full screen.
In the summer I use an ITC receiver on the 7R and it seems to get stuck on the commandcenter too, but the 2600 gets the GPS signal anyway. Its all one happy BUS. If you show the planter on the command center it will still document on the 2630. | |
