Posted 1/6/2012 01:00 (#2145791) Subject: Looking for info about Milton planters (pics)
Bow Island, Alberta
I was looking at a set of Milton planters the other day. These had been used for sugar beets many years ago. I want to use them for some small plots of other crops.
Does anyone have any information about operating them? For example, setting different planting rates, etc?
Posted 1/6/2012 09:30 (#2146119 - in reply to #2145823) Subject: Re: Looking for info about Milton planters (pics)
s nd
The only thing that drove the seed plate was the disc and depth band on it. Had to be perfect conditions. Closing wheels were straight, so no pinch like the deere. I think I still have the die to make them like the deeres closing wheels. That really helped that planter. You have to take the disc off to change the brass gear to change seeding rates. This is the old ones, now. I beat the vac planter in seed spacing on the test stand, short seed drop. Mine went to montanna, I believe. Good luck
Posted 1/6/2012 09:23 (#2146103 - in reply to #2145791) Subject: RE: Looking for info about Milton planters (pics)
NW Wyoming
We still use them for sugarbeets. They are an extremely accurate planter under most conditions both depth wise and spacing. The spacing is adjusted by changing the drive gear on the one disk opener that drives the seed plate. The other way to fine tune the spacing is to vary the amount of holes in the seed plate itself. They are very simple and easy to work on. The only drawbacks are that sometimes if you hit big rocks, the yoke for the closing wheels will break and if you plant into corn stalks or alfalfa roots, the trash will jam in the openers and they will drag. Just something to watch. The only other thing is that the hopper is small and has to be refilled often. They have changed the design on the closing wheel yoke and we haven't had any troble with new design yet. The bracket that the spring goes to between the closing wheel yoke in your picture is the old style by the way. They do make a monitor that tells when the seed plate is turning. They are made in Casper, WY by Starco Manufacturing. They are very good to work with if you need different seed plates, etc.
