I've got a Mercruiser engine that is getting fuel inthe oil. I'm gonna try and find a fuel pump for it but being a holiday weekend will make it hard to find the marine version. I'd probably have to drive a hundred miles to get one.
What is the difference in a marine and an automotive fuel pump? Or maybe put on an electric to get me by this weekend.
Posted 7/3/2011 11:51 (#1846663 - in reply to #1846387) Subject: RE: Marine fuel pump vs automotive fuel pump........
ne south dakota
The marine fuel pump that I have, has a glass sentiment bulb that collects fuel when the fuel pump leaks past the diaphram. Any fuel pump that will bolt on the same block will work, you just won't have the safety leak indicator. I would not use any electric pump in the enclosed engine compartment. any chance of ignition of leaking fuel is what you are trying to eliminate. Happy boating. bozranch
