NW Washington | I saved this post on this page that was posted years ago by SDMan who does not post here anymore or at least not by that name. I think the CIH big boys got on his case for some of what he was posting. But anyway here is his advise on CIH combines and improving their straw spreading which I think still applies. Thanks Jim.
"CIH Straw spreader performance improvements from SDman.
Just thought I would share some tips to help maximize performance with factory chaff spreader attachments. We have several 36' MacDon heads out here & have a lot of no-till so even spreading of residue is a must. With just a few mods., and not a lot of money, you can make a stock Axial-Flow the best at spreading residue evenly. Here are 5 major points for proper setup. 1) Be sure you have the straw deflector in the discharge hood for even distribution to the spreaders. This deflector was added at 1997 production & can be installed in older machines & is adjustable. 2) Trim back about the last foot or so of the curtain on each side of the spreaders about were the curtain makes the first 30 degree turn. You might want to cut the curtain off and keep it in your shed so you can install them for row-crop harvest so cobs are not thrown towards the rear of the combine. 3) Install the fast speed spreader pulley (part#1994772C1, also requires spacer #27828R1), this increases spreader speed from 227 to 346 RPMs. 4) Set the spreader bats to aggressive position(this is shown in operator's manual but I see very few of them set this way) you might want to mark the spreaders Right or Left so you do not get them mixed up when you remove them. 5) Case also came out with taller spreader bats that are taller than the factory ones. They recommend 3 of these bats on each spinner so that they alternate on the disc and that they alternate from each disc(short bat on LH spinner lines up with tall one on RH spinner, and vice-verse). The part #s for these are 321372A1 for LH on 88 series, 321373A1 for RH on 88 series; 323745A1 for LH on 44/66 series, & 323746A1 for RH on 44/66 series. These help spread tougher material such as green stem soybeans & help eliminate the "strip down the middle" that customers have complained about. With these simple mods, you will find these machines can spread evenly in most conditions. "
