| I know Icon/Landoll makes a pull type grader blade. What other mfgs make a beast like it? I have found a few via a yahoo search but they are all geared towards a small hp set up, I need one for 150 hp and above.
Also, I have seen some townships dragging a blade set up behind their motor graders. Was curious what and who makes those. Any help here??? |
 Brazilton KS | Crustbuster was the first one I saw around here. Then Icon showed up, and that's about all there is now. |
Huntley Montana | I bought a HYGRADE out of ND . 14' rear steer for $12000 LAST yr. I see some advertised in TRACTOR HOUSE 14' w rear steer for $14000. I bought mine direct. Tell them you do not want the cutting edge. Go buy it locally. M.ine kinda fell apart blading snow @ 0 degrees, don't think they are as good as the regular grader blades. I think mine is rated 300& hp
Edited by Badger 3/15/2009 22:04
| I'm thinking Johnson Mfg. makes one or two models in the 150+ hp category? |
Wilson, KS | What are ya lookin to use it for? We are pullin a Hy-grade up here at Wilson......got mixed feelings bout it. You can look it over if ya like. |
| Welding shops have converted old motor grader blade & turntable to 3 point blade with big tailwheel. Might watch sales. |
 Litchfield MN. | Check Double B Mfg. at doublebrepair-mfg.com
Wilson, KS | Whats the deal with the cutting edge.....didn't know there was an option. Fill me in. |
Huntley Montana | It was real brittle when cold. I hadn't got the paint off of it when it fell apart blading snow hitting rocks. I run the Degelman dozer @20 mph & never had it break like that. |
 Brinkley, Arkansas | Fair Oaks Manufacturing in Mccrory, AR makes one. I talked to them back in Dec. and they cost 10,300. They don't have a website but this is a pic of an older model I found.
http://www.blackmonauctions.com/Gallery/0c114815-4c60-47fe-8f46-da6... |
NW Washington | St John Welding has a pull type blade on their web page. http://www.stjohnwelding.com/St_John_Weldin/LevelAll_Landx.html |
