Are 11R/22.5 the same size as 295/75 22.5 ?
Rekus
Posted 11/4/2018 09:58 (#7083435)
Subject: Are 11R/22.5 the same size as 295/75 22.5 ?
WC Illinois
TIA. What’s the difference, Height wise?
Edited by Rekus 11/4/2018 10:04
Big Ben
Posted 11/4/2018 10:09 (#7083455 - in reply to #7083435)
Subject: RE: Are 11R/22.5 the same size as 295/75 22.5 ?
Columbia Basin, Ephrata, WA
Rekus - 11/4/2018 07:58
About an inch.
11r22.5 are the same height as low pro 24.5.
PatCMO
Posted 11/4/2018 12:01 (#7083659 - in reply to #7083435)
Pilot Grove, Missouri
They are really close. Like an inch in diameter one way or the other, can't remember which is taller though. Patrick
Walton Farms
Posted 11/4/2018 12:30 (#7083717 - in reply to #7083435)
SW Indiana
11R22.5 is the standard height tire.
295/75 22.5 is the low profile version
Each will go on the same rim, but shouldn't be mismatched together
assault
Posted 11/4/2018 12:33 (#7083721 - in reply to #7083717)
Iowa
11r are tall, just had to put a couple 285 24.5 on to get by and comparing them to the 11r 24.5 on the trailer they look tiny
Browtrucking
Posted 11/4/2018 12:51 (#7083752 - in reply to #7083435)
halfway between Lapeer and Port Huron, MI
295's are an inch shorter than 11r 22.5's they are however (the 295's) the same height as a 10r 22.5
GM Guy
Posted 11/4/2018 12:51 (#7083754 - in reply to #7083435)
NW KS/ SC ID
Too much to use side by side or anywhere on a drive axle IMO.
If you put a pair on one wheel position on a trailer that had 11r22.5s on all the other positions it wouldnt be a problem.
