Search Forums | Classifieds (61) | Skins | Language
Easy way to adjust case flagship faceplate (pics)
JAnderson
Posted 10/27/2018 10:35 (#7068133)
Subject: Easy way to adjust case flagship faceplate (pics)
McCanna, ND
This is the best way I’ve found to tilt the faceplate backwards on case flagships. My bar is big enough that going forward is easy and I don’t need anything else. Just stick a appropriate sized piece of wood along the two horizontal pieces of flat stee and it gives good leverage to pry against.
Edited by JAnderson 10/27/2018 10:36
(38EF8B3A-2F65-4CEE-BDF0-5DAC2CE7B802 (full).jpeg)
Attachments 38EF8B3A-2F65-4CEE-BDF0-5DAC2CE7B802 (full).jpeg (137KB - 87 downloads)
Greasemonkey18
Posted 10/27/2018 10:47 (#7068153 - in reply to #7068133)
Subject: RE: Easy way to adjust case flagship faceplate (pics)
When did they start using springs on feeder chain tensioner? I have been wanting to do that for years
School Of Hard Knock
Posted 10/27/2018 10:53 (#7068170 - in reply to #7068133)
just a tish NE of central ND
Isnt there any push pull eye bolts to move that plate? Its just dumb that they didnt come up with something better or quicker....A couple of hydraulic cylinders would be nice.
My 1680 has an eye bolt on each side that you can force the plate forward and backward and both my machines pivot on the bottom.
My 1480 doesnt have that and needs a sledge hammer,
https://www.homedepot.com/p/URREA-10-lbs-Steel-Octagonal-Sledge-Hamm...
Brandon
Posted 10/27/2018 10:53 (#7068171 - in reply to #7068153)
Illinois
The midrange machines started using it with the x088 series in 2009. Not sure on the flagships, maybe before that. It does take a heck of a lot of grief away from the chain adjustment headaches on the older
machines.
JAnderson
Posted 10/27/2018 11:19 (#7068218 - in reply to #7068153)
McCanna, ND
This is a 9120, I’m not sure if a 8010 had the springs for the feeder house chain or not.
If they had a turn buckle or hyd cylinder to adjust the pitch (would be nice) but, I could see it having issues like ripping the face plate off. If someone forgot to tighten the bolts and you start pounding through the field with 11-12k lb head bad things are going to happen. Takes more time to loosen/tighten the bolts then adjust the face plate anyways, 10-15min job
Cliff SEIA
Posted 10/27/2018 11:33 (#7068238 - in reply to #7068153)
Early 8010s did not have the springs, I think it was in '07 or '08 that they came about and there is a kit to retrofit them to older machines.
north1
Posted 10/27/2018 11:46 (#7068254 - in reply to #7068238)
North Dakota
I believe they came out with it in 09. I have an 08 8010 and it didn’t have it. The next year it was offered as a kit which I purchased and replaced old system.
Farms With CASE
Posted 10/27/2018 12:03 (#7068280 - in reply to #7068133)
North Liberty and South Bend, Indiana
It is beyond stupid these dont have the same setup the CR's have. They have a nice built in adjuster.
Tazzerblue
Posted 10/27/2018 12:24 (#7068310 - in reply to #7068280)
Subject: Lexion has the hyd tilt face plate. Requires a HD feeder house.
SW MN
My Older 580r has the turn buckle. no bolts to loosen or tighten. They will have it sooner or later. and charge $$$ for it.. I really like it to adjust the corn head angle. and I Love the MacDon's touch the button for adjustment.
Busted Knuckles
Posted 10/27/2018 13:01 (#7068353 - in reply to #7068133)
Southeast Minnesota
The other day when switching from beans to corn. I use a ratchet strap from the face plate to any convenient spot under the cab.
Newguy
Posted 10/27/2018 13:50 (#7068410 - in reply to #7068310)
Subject: RE: Lexion has the hyd tilt face plate. Requires a HD feeder house.
WC MN
Tazzerblue - 10/27/2018 12:24
And the Lexion’s 2014 and newer? Have a hydraulic cylinder in place of that turnbuckle. Simple genius. 350 dollar fix that companies will charge 4 grand to buy new when they adopt it.
BacNBlak
Posted 10/27/2018 13:56 (#7068418 - in reply to #7068133)
Eastern Shore of MD
I’m surprised they don’t have the cr set up as well. They have had threaded adjustment since 04 (I believe) for the angle of the fh. That also applies for the sprung feederhouse tensioner. On the subject, I don’t know why CNH didn’t put the 3 pt hitch mount on the Case feederhouses either. Such an easy easy to remove the whole throat of the machine.
Fred
Posted 10/27/2018 17:03 (#7068620 - in reply to #7068133)
south east SD
My John Deere I just use the 2 buttons on the handel in the cab :>)
Someone had to say it!?
STOMN
Posted 10/27/2018 19:37 (#7068842 - in reply to #7068133)
West Central MN
I just put the head on the ground and loosen thebolts.
STOMN
Posted 10/27/2018 19:50 (#7068869 - in reply to #7068620)
West Central MN
Fred - 10/27/2018 17:03
It’s always funny when JD guys are naive and believe only deere has something.
cotnhill
Posted 10/27/2018 20:09 (#7068907 - in reply to #7068133)
North Carolina
Loosen bolts, put your bar through the holes on the top of faceplate and lift it. Might have to use one on each side.
CowsNPlows
Posted 10/27/2018 20:22 (#7068937 - in reply to #7068842)
SW Nebraska
X2
Kooiker
Posted 10/27/2018 20:38 (#7068970 - in reply to #7068410)
Newguy - 10/27/2018 13:50
Tazzerblue - 10/27/2018 12:24 My Older 580r has the turn buckle. no bolts to loosen or tighten. They will have it sooner or later. and charge $$$ for it.. I really like it to adjust the corn head angle. and I Love the MacDon's touch the button for adjustment.
Maybe I'm dreaming but I could swear that the first time I ever climbed around on a 400 series Cat/Lexion combine at the Clay County fair 19 (?) years ago that they had a hyd tilt face plate on the feeder house then already.
IADAVE
Posted 10/27/2018 21:00 (#7069023 - in reply to #7068907)
I determined that mine was in just the right place when I tried to loosen the bolts holding it. !
Newguy
Posted 10/27/2018 21:46 (#7069125 - in reply to #7068970)
WC MN
Kooiker - 10/27/2018 20:38
Our first 470 Lexion was 18 years ago. We’re talking forward and rear from cab tilt. Wasn’t available until recently. 500’s had turnbuckle by hand in o5-06 era.
Fred
Posted 10/27/2018 21:57 (#7069155 - in reply to #7068869)
south east SD
STOMN - 10/27/2018 18:50
Panties in a wad?
No where did I say JD was the only company who has that feature.
Mine was tounge in cheek. Sooo that doesn't make you Mr Obvious.
RRVND
Posted 10/27/2018 22:05 (#7069171 - in reply to #7068842)
X3
Kooiker
Posted 10/27/2018 22:08 (#7069176 - in reply to #7069125)
Newguy - 10/27/2018 21:46  Our first 470 Lexion was 18 years ago. We’re talking forward and rear from cab tilt. Wasn’t available until recently. 500’s had turnbuckle by hand in o5-06 era.
Yeah, that's what I'm talking about also and was sure that the first time I ever crawled around a 400 series that it had it hyd adjustable from the cab.
Could be losing my mind already.
sharecropper
Posted 10/27/2018 22:47 (#7069227 - in reply to #7069171)
southern tip Illinois
X4
Red wrench
Posted 10/27/2018 23:13 (#7069247 - in reply to #7069227)
South central MN
I always put the head on it, latch it, put it on the ground to take the weight off of it and loosen the bolts. Then use a magnetic angle gauge to determine header angle or deck plate angle. Use a cordless impact. This is on a 7088
STOMN
Posted 10/28/2018 08:32 (#7069615 - in reply to #7069155)
West Central MN
Take it easy.
Farms With CASE
Posted 10/29/2018 07:47 (#7071585 - in reply to #7068133)
CR feederhouse. Looks like the CR's should be referred to as the Flagship of the CNH harvesters as they seem to have all the goodies.
(20181029_083750 (full).jpg)
Attachments 20181029_083750 (full).jpg (261KB - 41 downloads)
turnipted
Posted 9/25/2023 07:33 (#10415264 - in reply to #7069247)
Red wrench, Have a 5088 and was wondering how you get an impact on that lower nut on left side of feeder house? Use socket extension on other nuts but the header latch bar is in way for that lower nut on that side and too tight of space to get one on nut on the inside.
Also, what angles are you happy with on bean head and corn head ? Assume angles read off back tinwork on bean head and the deckplate on corn head?
Thanks in advance for your help!!!!!
Red wrench
Posted 10/1/2023 13:45 (#10423505 - in reply to #10415264)
South central MN
I don't have any issues on the left side but on the right side I have issues being mine has the 2 speed gearbox. I run 16-17 on bean head, 22-23 on corn head
turnipted
Posted 10/13/2023 09:16 (#10438706 - in reply to #7071585)
Like the CR's better with the "turnbuckle" adjustment and position indicator......pretty simple!
turnipted
Posted 10/13/2023 09:22 (#10438715 - in reply to #10423505)
Thanks!!
