Search Forums | Classifieds (26) | Skins | Language
hydraulic hose cost
farmdude
Posted 10/10/2018 13:48 (#7038338)
Subject: hydraulic hose cost
So what are you guys paying to have new hydraulic hose made an ends put on? Just curious.Per foot price.Thanks
W Bench Farms
Posted 10/10/2018 14:17 (#7038408 - in reply to #7038338)
Subject: RE: hydraulic hose cost
Lisbon, OH
Just had a 3 1/2' - 3/4" ID hose with 1/2" male ends made at NAPA yesterday for a dozer. They charged me $45. Gave me a deal, because my normal fleet cost for just the parts would be about $70. Sign up with AITA, get fleet pricing at NAPA.
Hay Hud Ohio
Posted 10/10/2018 14:21 (#7038416 - in reply to #7038338)
SW Ohio
Size?
Less than $2.00 per foot plus fittings.....another ten bucks???
We make our own..... https://www.discounthydraulichose.com/
Galaxie64
Posted 10/10/2018 14:23 (#7038418 - in reply to #7038338)
WY, OK
WAY too many variables. so answer is $1-$10
thefoolishfarmer
Posted 10/10/2018 14:25 (#7038422 - in reply to #7038338)
South cental Ohio
Approximately half inch JIC ends ( I don't know the size in JIC terms) cost $9.53 . Hose was $6.08 a foot. then they charged $3.00 a crimp. Ridiculous !!!!!
hydro70guy
Posted 10/10/2018 14:33 (#7038438 - in reply to #7038338)
Swaledale, IA
Last time I went to make a hose for the sprayer O'Riellys was $120 for the same hose as CAT charged $60 for. So there is a lot of difference. Hydraulic hose is expensive anymore. I buy those cloth mesh protectors for anywhere a hose can rub anymore.
Edited by hydro70guy 10/10/2018 14:34
Jerry/MT
Posted 10/10/2018 14:36 (#7038444 - in reply to #7038338)
The Palouse North Idaho
If you don't need it right away, Surplus Center or Agri Supply have good prices
Stout Farms
Posted 10/10/2018 14:46 (#7038460 - in reply to #7038438)
Do you have a farm plan at O'Reillys? We do, and if you tell them to put it under your farm account, it reduces the price A LOT. Anything AG related like that will work. It has even worked for a few rotors we bought for the vehicles.
JRM
Posted 10/10/2018 18:02 (#7038796 - in reply to #7038338)
MN
Just had one done yesterday at Ziegler. Was cheaper than piecing the right fittings together on a premade hose. 1/2” hose rated for at least 3,000 psi. They charged $.36 per inch (this was a short hose) plus $7.23 per fitting for a male and female JIC. Then there’s a flat rate for hose assembly. So I paid the most per foot you’d likely see since it was only a 16” hose. The longer the hose, the less it would be since it’s a flat rate for doing it.
Total was $45 I was happy with that. Copied the exact hose it replaced and didn’t have to mess with anything.
This was the first time I had Ziegler do a hose, normally go through local fleet store. After watching them, I’ll likely never go anywhere else. Don’t think I’d really save much and they pay a lot more attention to contamination control and quality. I’ve always seen the person just blow out the hose where Ziegler actually had a special plug the blew through it to get any debris out. Also measured each crimp when done, I’m assuming to make sure it crimped properly.
(D101E6A9-A997-4643-B0DE-E64893C58078 (full).jpeg)
Attachments D101E6A9-A997-4643-B0DE-E64893C58078 (full).jpeg (229KB - 200 downloads)
School Of Hard Knock
Posted 10/10/2018 18:12 (#7038819 - in reply to #7038338)
Central ND
Like these?
(20181010_180952 (full).jpg)
Attachments 20181010_180952 (full).jpg (143KB - 202 downloads)
farmdude
Posted 10/10/2018 18:43 (#7038889 - in reply to #7038819)
Got my hose.8 ft for$25.00. This is half inch 3000 psi.Got two off them.I think I did alright.Thanks for all the help
Nodak63
Posted 10/10/2018 19:32 (#7038991 - in reply to #7038796)
NE ND
I never knew anyone did such a thing. Always had em made st the local Deere dealer. They never have blown me out, I never even thought o fit, and no measurements. But I’ve never had a problem I guess.
dt4020
Posted 10/10/2018 20:22 (#7039145 - in reply to #7038444)
Fairbury, NE (Southeast)
Yep if you are working on a project they have various lengths and sizes. Good quality hose as well. It cost 1/3 of what the local wanted.
dave morgan
Posted 10/10/2018 22:42 (#7039551 - in reply to #7038991)
Somerville, Indiana
Nodak63 - 10/10/2018 08:32
Cat blows a plug through the hoses, they advertised that a few years back..
yellowfever
Posted 10/11/2018 09:47 (#7040173 - in reply to #7038338)
I buy most of my hoses online when I can wait... either pre-made standard lengths and ends or call places that custom make them. There is a place in Grand Island that makes hoses reasonably and ships same day, believe they changed their name to applied hydraulics or something. Few other good places if you google around a bit.
nekfarmer
Posted 10/11/2018 12:18 (#7040490 - in reply to #7040173)
NE KS
Our local guy sprays brake cleaner in the hose then blows it out before crimping the end. I had some hoses made at CAT a while back and he just blew them out, not plug. My biggest complaint about flucon and cat is they make the hoses a pinch long. I understand longer is better than too short but some of the big heavy hoses can be a bear to get in place.
Edited by nekfarmer 10/11/2018 18:09
JRM
Posted 10/11/2018 12:25 (#7040509 - in reply to #7040490)
MN
The guy that made my hose made it exact. He cut the hose a couple times to get it perfect. Cut it, pushed the ends to measure difference, then trimmed and doubled checked. Hose went between a hard line and the base end of a cylinder and it fit perfect.
